Introduction: Infinite Cube
This Cube is a super easy to make infinite mirror illusion cube, needing just five affordable supplies you can make it yourself!
- Plastic sheets (you can find these on amazon.com and make sure they're the stiff kind!
- One-way window privacy film (also available on amazon.com
- fairy lights (small lights that are battery operated (also available on amazon.com)
- scissors
- hot glue and hot glue gun
Step 1: Cut Out Squares From Plastic
Cut 6 1.5" by 1.5" squares from the plastic.
It will crack, but this does not affect the outcome.
Step 2: Apply Film to Plastic
peel off the protective plastic from the film. And stick onto the plastic squares one by one. Last cut them out.
Step 3: Hot Glue the Square
Now that all the squares are mirrors glue all of them into a cube shape except for one. (I do not have a photo for this unfortunately.
Step 4: Shove the Lights Into the Box
Since one square is still unglued, insert all the fairy lights into the cube, but be careful not to include the battery pack inside.
Step 5: Glue the Last Square on Top
Once all the lights are in and not popping out you can proceed with gluing on the last square.
Step 6: Enjoy!
Thank you for scrolling all the way down here I hope you found this instructable easy enough to understand!
