Introduction: Infrared Alarm Sensor
This device will set off an alarm if someone try's to steal something from you.
Step 1:
You will need an Arduino, bread board, five wires, normal alarm, and a IR sensor
Step 2:
You will need to set up the wires this way in the right areas so they can sink with the code. You can find a code on the internet, you may need to change it so it will work with the sensors and alarm. Try to find a small box to fit everything into.
Step 3:
I am using just a normal box for this demonstration, you will be able to put this alarm almost anywhere. I suggest taping down the box and wires so they don't fall out.
Step 4:
You will also need a power source for the Arduino, this will not take that much power. Mine is running off of 3.3V. It should be able to fit in the box.
Step 5:
https://youtu.be/gIkUx_YPKCI here is a link to a video to show that it works
Step 6:
This is where I got my code from. I had to change it some to work for my expectations. https://learn.adafruit.com/ir-breakbeam-sensors/overview Good luck in making this project.
