Ingenious Fruit Berry Harvester Home Made From a Plastic Bleach Bottle in Action.
Intro: Ingenious Fruit Berry Harvester Home Made From a Plastic Bleach Bottle in Action.
Simple Fruit / Berry Picker in action, picking ripe blackcurrants without damaging the berry's. (Video)
Click here to see video of Fruit Picker in Action
The picker is made from an empty bleach container, which provides a comfortable handle.
The cheap bleach cost 23 pence from Asda and most supermarkets.
The screw cap end of the bottle can be used to secure a pole to reach distant fruits, by screwing through the threaded neck into a cane or wooden pole, inserted into the neck of the bottle.
The fruit picker helps to decrease the harvesting time, while making it very easy to harvest fruits, especially where the plant has prickles. Berries such as blackberry, gooseberry, raspberry, elderberry, bilberry, redcurrant and blueberry can be picked with ease using this excellent free harvester.
Very pleased with the results and making use of containers we frequently discard makes it a very worthwhile project.
Please come back and share your experience
Thank you for watching my video and please check out my research into circulation and inclined bed therapy at http://inclinedbedtherapy.com
STEP 1: Locate a Plastic Bottle of Cheap Bleach From Your Supermarket
Cheap bleach cost for us is 23 pence, which makes you wonder how they can make a profit?
You need the type that has a handle on it and is made from tough plastic, don't settle for anything less.
Wallmart is the equivalent to Asda in the USA
Once emptied you need to thoroughly wash out the empty bottle, several times to remove all traces of bleach.
Make sure you don't get any on your clothes and if you do, immediately wash your clothes under the tap to avoid bleach damaging them.
STEP 2: Cutting the Bleach Bottle to Make Your Ingenious Fruit Picker
- With the bleach bottle on a firm surface, have the handle pointing up.
- Using a box cutter, saw or scissors, cut half way down through the side of the bottle below the handle as shown.
- Then cut horizontally along from the bottom to the first cut that you made.
This will create a funnel for the berries to roll towards the capped end and prevent you from losing any as you gather more.
STEP 3: Now You Need to Add Some Teeth to Your Ingenious Fruit Picker
Using sharp strong scissors or a box knife / Stanley Knife, cut V shaped teeth in the end of the bleach bottle to create the comb that will dislodge the softest fruits without damaging them and capture the berries in the bleach bottle, enabling you to work for much longer between visiting your basket / storage container.
This Ingenious Fruit Picker will enable you to strip berries from the branches of fruit bushes, shrubs and even trees without staining your hands.
Especially in protecting you from those species that rip your hands with sharp thorns, such as gooseberry and blackberry.
To reach fruits further away, drill a hole through the plastic cap and insert a wooden mop / broom handle, then screw through the bleach bottle threaded neck into the pole. No more fruits out of reach :)
Hope you enjoyed this Instructable as much as we did eating all of those yummy blackcurrants :)
Kind regards
Andrew
website: http://inclinedbedtherapy.com
11 Comments
f1dd13r 4 years ago
tenbury 5 years ago
Andrew mate, that's brilliant. I've been growing currants for 4 decades, why didn't I think of this!
As I can't presently move ( broken hip) this is exactly the kind of project for me.I'll be hunting under the sink for a bleach bottle later today.
Thank you.
tammycntn 7 years ago
So glad you posted this. Love this great idea.
AndrewKFletcher 7 years ago
:) Thanks for you thumbs up
WilliamB274 7 years ago
Yes, that was me taking my eye off what I was doing :) It works very well and those berries that fell were knocked off by me rather than falling out of the scoop.
That said, your idea of adding a hose sounds promising.
YourMagesty 7 years ago
THIS IS BRILLIANT!
Thank you "Your Magesty" :)
Heyup 7 years ago
Great idea Andrew, well done..... John from sunny Donny :)
Thanks John, it is very comfortable to use close up. Will take some more picks and footage with one extended on a pole to reach those fruits other pickers can't :)
UK Berries are ripe for harvesting right now. bilberries, raspberries, blackcurrant, blackberry, In the North, gooseberry
