Ink Blot T-shirt
Intro: Ink Blot T-shirt
Make a t-shirt in the style of a Rorschach ink-blot. The resulting design will be essentially random but laterally symmetrical.
STEP 1: Materials
You'll need:
- a t-shirt; either white or light-colored
- a piece of corrugated cardboard, roughly the size of your t-shirt
- t-shirt paint; black or other dark color
- thumb tacks or a stapler
Crease the cardboard lengthwise down the center.
The thumb tacks need to be flat. Push pins won't work. Staples might work if you don't have tacks.
STEP 2: Setup
Insert the cardboard into the shirt, taking care to keep it centered. Tack down the shirt along the outer edge and near the crease at the top and bottom. Try to keep the shirt straight and pulled tight without stretching it. When you fold it, the shirt should not gap or pull away from the cardboard too much.
STEP 3: Apply Paint
Slop some paint on the shirt. A few blotches and splatters should do. Try not to intentionally draw a design.
STEP 4: Fold the Shirt
Fold it in half. Close it firmly but don't overdo it. You want it to spread a bit but not to smudge too much. Don't leave it too long. A few seconds is plenty.
STEP 5: Open and Let Dry
Open the shirt again and leave it to dry. The paint will probably bleed through to the cardboard and stick. You should be able to peel it off if you're careful.
STEP 6: Variations
You can make a multi-colored design by repeating the process, letting each layer dry.
If you use a smaller piece of cardboard, you can create several separate designs on the shirt (front, back, sides).
100 Comments
WUVIE 7 years ago
I just love this idea. We live in an area where one can purchase all-you-can-stuff clothing into a plastic bag for anywhere from two to seven dollars. This would be a superb project for an entire classroom, costing very little to the teacher and/or students. Thank you for sharing
bajecat 11 years ago
McGrep 12 years ago
I used some binder clips instead of pins/adhesive spray and it turned out just peachy.
feistydonut 12 years ago
ilpug 12 years ago
Jsquared24 12 years ago
Jar Sqwuid 12 years ago
CthulhuCaller 12 years ago
gallius 12 years ago
doze 12 years ago
Foxtrot70 12 years ago
mootheflyingcow 12 years ago
mvieke 12 years ago
uhomeniuk 13 years ago
kkristjánsdóttir 13 years ago
Rskate2 13 years ago
scolon 13 years ago
Nyxi 13 years ago
Paris121 13 years ago
Whales 13 years ago
