Introduction: Ink Removal From Soda Cans
Soda cans are involved in all kinds of "reuse" projects. If you have no idea just use the search bar on the instructable homepage desktop and type in "soda cans" and you received various results with projects where soda cans are reused.
However, if you need the can for some more decorative purpose the inprints on the outside wall of the can makes it useless. Therefore, this instructable demonstrates an easy method for ink removal on soda cans. As a result, you will end up with a can having a nice shiny outer surface as given on the picture. In this instructable a vase for flowers was built (see last step).
Step 1: Materials
Only few materials are needed for this project:
- Soda cans
- Nail polish remover
- Cotton pads
- Pressure cooker
- Hot plate
Please use various types of soda cans for your first project. Even so the procedure worked for almost all cans some did resist to the procedure.
Step 2: Method
Surfing through the internet you will find some procedure using sandpaper to remove the ink. However, with this procedure you will never end up with the polished shiny outer surface that you want for your decorative reuse project.
During the first attempts, various solvents were used e.g. nail polish remover or pure acetone directly. But as you can see in the attached video none of them did work.
Here is the trick: Put the cans in a pressure cooker for around 20 minutes.
Attention: ONLY ADD EMPTY CANS IN THE PRESSURE COOKER
Use the procedure that comes with your pressure cooker for sterilizing liquids. In my case I have to add a little bit of water to cover the bottom of the sterilizer. Then place all soda cans inside and close the lid. On the hot plate, I use maximum power to start (level 6 of 6). As soon as the pressure indicator reaches the second mark (2 of 2) power of the hot plate is reduced immediately to level 2 (level 2 of 6). Sterilize it for around 20 minutes.
After 20 minutes take away the pressure cooker from the hot plate and wait until the pressure is released. Then open the cooker carefully (hot vapor) and take out the cans.
Add some drops of nails polish remover to the cotton pad and start removing the ink.
Step 3: Make Your Reuse Project
As shown in the video the bottom part of the soda can was removed and the lid was opened using a tin-opener. A 300ml PET flask was found that fitted directly into the polished soda can. The PET flask was shortened to the correct length and then fixed into the soda can with hot glue.
I hope you like this creative reuse of a soda can which turned into a vase for flowers.
Glue Challenge 2016
3 People Made This Project!
- thescientistformerlyknownasNaegeli made it!
145 Comments
2 years ago
I just used my oven set to 425F or 218.333C for 45 minutes and then rubbed nail polish remover with steel wool on the cans and got the same results as i got with the pressure cooker.
Reply 5 weeks ago
For me, baking it at 480F or 250C for an hour and half in the oven did not work.
Reply 1 year ago
Did you try lower temperatures and build your way up to 425 degrees? Thanks for posting. I don't want to do this to my brand new instant pot and it would take forever if I used it anyway with how many cans I want to do.
Reply 2 years ago
I have not tried this combination - did you get any odor from the ink when placing it in the oven at such high temperatures?
Reply 2 years ago
It smelled like i was baking brownies but that was likely some residue from the former contents which were Java Monster energy drinks. I've used the oven to flatten sheets cut from cans for years. The nail polish remover or lacquer thinner to strip the ink was the last piece of the puzzle for me so I'm thankful for your instructable.
Reply 2 years ago
okay - then I will also have a try.
I guess you have seen my instructable to flatten the sheets with an electric iron. Do you have a jig for the sheets when you put them in the oven?
Reply 2 years ago
Just a pair of bricks I found one day. I put it on top of 5 aluminium sheets to get them to lay down flat. I have two bricks, so i can do 10 sheets at a time. I didn't do any experimentation with the time or temperature since I got the result I wanted the first time. I did find that if you have too many sheets then not all of them will remain fully flat when the process is complete.
Reply 2 years ago
Question 3 years ago
How did you convince your wife before using HER loved pressure cooker? Mine did not allow me?
Answer 1 year ago
Buy your own... or are you assuming that only women can own pressure cookers?
Answer 3 years ago
... sometimes you just have to start an experiment ... and you don't ask for permission. I guess if you are married for a long time you can anticipate the answer in advance and then act accordingly (smile)..... but you know my wife has a hard time with me anyway. I just recently had to buy my own fridge because she did not want to have the worms I need for fishing in the same fridge anymore ..... so compare this to the pressure cooker problem.....wish you happy family life - I am now married for 22 years!
2 years ago on Step 3
Cheaper to buy lacquer thinner than nail polish remover. Same product without the perfume.
Question 3 years ago on Introduction
Hello, this tip will come in very handy for my garden art business. I’m wondering however if I can do this in an electric pressure cooker, and if so what would the settings be? Also, is it safe to just wash the pressure cooker insert afterward and still use it for food?
Reply 2 years ago
Actually I don't know what you mean by electric pressure cooker. In case it is just a closed pan generating saturated steam inside with a high pressure then it should work.
Is it safe? I don't know! I do not have any safety data. But for myself (and my family), I use the same pressure cooker for food and for removing the ink since 3 year known. I always clean the pressure cooker after I have used it with soda cans. Consider that after the soda can is taken out of the pressure cooker no debris or residues on the inside can be found. So I really think it is just the vapor (saturated steam) going inside the lacquer and making the surface susceptible for the solvent. Hope this helps.
Question 3 years ago on Step 3
Can you use a normal pan with a lid or does it have to be a pressure cooker?
Answer 3 years ago
You really need to use a pressure cooker! If you just boil it in a pan of water it does not work.
4 years ago
I have done this except I didn't use a pressure cooker but lightly torched it with some flaming methylated spirits then use nail polish remover and it came out shiny as silver
Reply 3 years ago
YESZ, tell us more.
Reply 4 years ago
... hey cool - after some many views to this instructable you are the first one presenting a constructive new way - I will definitely test it for shure .. thanks for your feedback
4 years ago
However, if I remove all the ink, I can't get my deposit back!
