Introduction: InstaMorph W/ Digital Induction Warmer!
InstaMorph is a special crafting thermoplastic designed to heat up so that it can be manipulated like modeling clay. Once it cools, it hardens into place. Later, it can be reheated to be manipulated again.
You can see find out more here:
This was part of an Instructables Build Night with our Hackerspace:
https://www.knoxmakers.org/about
In this tutorial, we will show you how to bring your InstaMorph to the suggested 150 degrees F using a digital induction warmer.
Step 1: You Will Need:
For this project, you are going to need:
- InstaMorph
- A digital induction warmer
- Tongs
- Olive oil
- Water
- A metal pan designed for a digital induction warmer
Step 2: Heat It Up!
Set the digital induction warmer to 150 degrees F and bring the water to temperature.
Then, add in the InstaMorph.
We're looking for the pellets to turn clear and start clumping to one another.
You can see more detailed instructions here:
Step 3: Take It Out!
Now, you can remove the InstaMorph carefully with tongs or another tool.
Make sure that your tools are coated with olive oil so that the InstaMorph will not stick to them!
Wait a few seconds or so until the InstaMorph is cool enough to touch and you should be fine!
Make your creations now and enjoy!
