Introduction: Install Arduino IDE 1.8.2 on Linux
When I tried to install the Arduino IDE 1.8.2 on Linux like the
guidance on the Arduino website proposes, the install script returns multiple errors and i got very frustrated.
To prevent others from getting in that mood, I will share my solution, which i found, with you.
You only have to make little changes in the script and the installation will run flawlessly. This tutorial is for version 1.8.2 !
Step 1: Download the Arduino IDE
Go to www.arduino.cc => Software and download the package which fits to your system.
Step 2: Extract
Go to your Downloads directory and right-click on the downloaded arduino-1.8.2-linux64.tar.xz file or whatever your file is called.
Then click extract here and wait until you see two Arduino folders.
Step 3: Open Terminal
Go to your Downloads directory with
cd Downloads
and delete the compressed file with
sudo rm -r arduino-1.8.2-linux64.tar.gz
Then move your extracted Arduino file into the opt directory with
sudo mv arduino-1.8.2 /opt
Change into /opt directory and into the Arduino folder
cd /opt/arduino-1.8.2
Edit the install.sh script with
sudo nano install.sh
Search in the script for the line "RESOURCE_NAME=cc.arduino.arduinoide" and change it to "RESOURCE_NAME=arduino-arduinoide".
Step 4: Installation
Now make the script executable with the command
sudo chmod +x install.sh
and execute it with
./install.sh
Now you will not see any errors or bugs for the installation and you have the Arduino IDE flawlessly installed!
1 Person Made This Project!
- ZellitoH made it!
7 Discussions
7 months ago
UPDATE: The 'install.sh' has now been corrected by Arduino so you don't need to modify it. Just do the rest and remember to use 'sudo' before running the script, i.e. sudo ./install.sh
That's how it worked for me.
11 months ago
The last line is sudo ./install.sh not ./install.sh. But Thanks, this helped me
1 year ago
Just installed arduino-1.8.10 to Ubuntu 19.10 using the home/snap directory. Step 3 wasn't needed as the file already was in the format RESOURCE_NAME=arduino-arduinoide. But great guide.
1 year ago
Thanks so much from me too! I did not need to edit the cc.arduino etc as it was already done, but it helped me install from the terminal....thanks!
1 year ago
On linux 1.8.8/linux64 version, you may have to navigate to the arduino-1.8.8 folder inside an outer, once you've moved things to /opt. However, as things turn out, there's no need to change the RESOURCE_NAME, it's already as one wants it.
1 year ago
Thank you so very much !
I needed this......
3 years ago
Good idea. It gives a few more options on how to setup an Arduino.
