Introduction: Install BMW MINI Cooper Error-Free LED License Plate Lights
Let's learn how to install the xenon white error-free 24-SMD LED license plate lights for the following BMW and MINI Cooper models:
- 2004-2011 BMW E81/E87 1 Series 3-Door or 5-Door hatchback only
- 2014-up BMW F20/F21 1 Series
- 2004-2010 BMW E63/E64 6 Series
- 2011-up BMW F06/F12/F13 6 Series
- 2003-2008 BMW E85/E86 Z4
- 2009-up BMW E89 Z4
- 2014-up BMW I01 i3
- 2007-2011 MINI Cooper R55 Clubman
- 2011-2016 MINI Cooper R60 Countryman
- 2013-2016 MINI Cooper R61 Paceman
The xenon white LED license lamps are equipped with CAN-bus controllers so you won't have to worry about any bulb-out messages appearing on your dashboard computer. Installing the LED license plate lights is a simple plug-and-play process so you can quickly start enjoying the high output and color you will show off to drivers behind you.
Step 1: Take Out Your Stock License Plate Lights.
Step 2: Unplug the License Light Connector From Your BMW or MINI's Stock Harness.
Make sure you only pull off the license lamp connector and not the socket adapter.
Step 3: Connect the LED License Light to Your Stock Harness.
Plug the pigtail wires in between your stock harness and error free LED license lamp.
Test the LED license plate light to make sure it fully lights up.
Step 4: Final Steps
Wrap the connection with black tape to completely seal it from moisture coming in.
Snap the LED license lamp assembly back in to finish.
Enjoy the super bright output of the xenon white error free LED license plate lights on your BMW or MINI Cooper!
Find this and more OEM replacement LED lights at store.ijdmtoy.com today.
