Introduction: Install LED Grille Marker Lights on Toyota Tacoma 4Runner Etc.
Let's how to install the Toyota amber lens LED grille marker lights onto such vehicles as:
- 2012-up Toyota Tacoma TRD Pro
- 2014-up Toyota 4Runner TRD Pro
- also best fit on many other Tundra, Tacoma, or 4Runner trims
The 3-piece kit (also in smoked lens) comes with all the parts you need to custom fit the truck LED marker lights including a set of mounting screws and zip ties. Please note that because this is a highly retrofit kit, exact fitment is not guaranteed and modifications such as drilling, cutting, and wiring may be required to install the LED grille marker lights onto your Toyota grille mesh. With this DIY retrofit kit, however, you'll be able to enjoy the fruits of your labor and be surprised at how easy this installation actually is!
Step 1: Remove Your Front Engine Shield.
Unscrew the bolts to reveal the back side of your Toyota grill.
Step 2: Line the LED Marker Light on the Grille Mesh Location of Your Choice.
Step 3: Mount the LED Grille Marker Lights Using Hardware or Zipties.
Step 4: Repeat Step 2 As Needed.
Step 5: Wire the LED Grille Marker Lights.
Wire the black wires to the same ground connection.
Wire the red wires to the same running light harness.
Retrofit wiring actions are required to power the Toyota LED grille marker lights.
Step 6: Final Steps
Test each connection to make sure the LED grille marker lights light up properly.
Once you have, re-bolt your front engine shield to finish.
You may now enjoy the custom look of your Toyota Tundra, Tacoma, or 4Runner! Find this and more truck lighting & accessories at store.ijdmtoy.com today.
