Introduction: Install Led Driving Light on Jeep Wrangler
Some Jeep Wrangler owners always complain that the supplied headlights are high energy consumption and have the very poor lighting effects. They need suitable replacement headlights eagerly. Hence, in order to help more such customers, Auxbeam Lighting has released a new series of Hi-Lo LED headlights. It is 7 inch high and has a round shape, and the cutting edge LED technology makes the headlight to be long lasting, minimal energy consuming and super bright. They are applied to 1997-2015 Jeep Wrangler, and 1993-2014 Land Rover Defender, too.
The Hi-Lo LED headlights housing is made of aluminum for extra durability while doubling as heat sink and this solid-state can withstand vibration & shock with ease. The round projector and D-shape projector lens is another selling point of the headlights. They have two modes: high beam and low beam. The 40W high beam needs all LEDs on, the 20W low beam needs only two side LEDs on. Never mind, if you purchase it, it will come with a H13 to H4 adapter harness for Jeep Wrangler JK, which guarantee the headlight can directly replace stock 7 inch round seal-beam headlights. We promise that all products are tested to fit your vehicle and function like the original. Later i will tell you how to install led driving light on Jeep Wrangler.
Step 1:
Step 2:
Step 3:
Step 1
Remove the screws and clips holding the front grille in place.
Remove the front grille so you can gain access to the headlights.
Step 4:
Step 2 Remove the four screws that are holding the metal bracket ring around the headlights.
Step 5:
Step 3
Remove the metal bracket ring.
Step 4
Unplug the adapter and remove the stock headlights.
Step 5
Replace back with the Jeep Wrangler LED headlights the same way they were removed and connect the adapter.
Step 6
If your head beam does not work at all during the initial installation, please check both the adapter on the LED headlights and the LED driver module box.
Make sure no pins are pushed out.
If the problem persists, you may need to re-pin the adapter.
Step 7
If the high beam takes a couple tries to turn on, it means that there is not enough power being supplied.
The battery may need to be replaced or you may have to add a relay harness to directly draw the power from the battery.
Step 8
If you experience the issue where your high beam is periodically flickering, you will need an anti-flicker decoder to solve the problem once and for all.
Step 9
Sometimes, the issue will be localized on one side only.
If that’s the case, you will need to switch the LED drivers module box from the driver side to passenger side and vice versa to see if the module box is the issue.
Step 10
Once your Jeep Wrangler headlights work, put the ring and the screws back. Once everything is secure, reinstall the front grille.
