Install RockBox on an IPod (easy Steps)
Intro: Install RockBox on an IPod (easy Steps)
This instructable i am going to show you how to install RockBox, an open-source operating system for iPod!
First things first:
Installing RockBox will void your warranty. Also I am not responsible for any damage and/or data loss done installing RockBox on your iPod.
Proceed at your own risk.
Ok now thats over with heres what you need.
-an iPod
it can be a nano 1st gen, ipod 1g,2g,3g,4g or 5g but not classic.
(if you dont have a clue which iPod you own have a look at this. http://support.apple.com/kb/HT1353)
-The .rockbox build. get the appropriate one for your iPod here: http://www.rockbox.org/download/
- ipodpatcher: this handy little program will patch the bootloader on your iPod so that it can load rockbox properly. get it here : http://download.rockbox.org/bootloader/ipod/ipodpatcher/win32/ipodpatcher.exe
EXTRA: To enhance RockBox you can get extra fonts get them here
http://download.rockbox.org/daily/fonts/rockbox-fonts.zip
To run the game plugin "Doom" you'll need a base WAD
get it here : http://download.rockbox.org/useful/rockdoom.zip
That's it. Your all set.
Make sure to view the pictures and screenshots in high res
First things first:
-an iPod
STEP 1: Extracting
Find the zip folder where you downloaded the zip for your .rockbox build.
If you haven't got one yet get the right one for your iPod here: http://www.rockbox.org/download/
(Make sure you get the right one. Don't get the 30gb video and 60/80gb videos builds mixed up)
Extract the '.rockbox' folder from the zip to the root directory of you iPod's drive. (the root directory is the main directory of your disk. e.g E:)
If your iPod isn't showing up in my computer, it is because you haven't enabled disk use
You can do that by following these steps: http://support.apple.com/kb/HT1478
Now we can move on to the next step.
STEP 2: Patching the Bootloader.
This part looks scary but isn't.
All you need to do is connect your iPod and open ipodpatcher
(available here: http://download.rockbox.org/bootloader/ipod/ipodpatcher/win32/ipodpatcher.exe )
Once again I am not responsible for any damage, and/or data loss.
It will show a black window with white text. If you have plugged in a supported iPod it will display some info about the iPod and ask you to enter i to install and u to uninstall.
type i and press enter
If all goes well this process should take about 10-20 seconds.
STEP 3: Testing It Out.
Now for the fun part.
Now all you have to do is disconnect your iPod.
To reboot Press and hold menu+select (center button) for 6 seconds. Your iPod will show the Apple logo and then will show a RockBox screen. If you get back to the original iPod operating system reboot again without hold on.
Note: to boot into the Apple firmware (the original operating system) as soon as you see the Apple logo on the iPod's screen flick the hold switch on.
Also note: if you are using an iPod 1g,2g or 3g you will need to press and hold Play/pause+menu to reboot.
If you get an error and cant get to either operating system (apple or rockbox) and/or are shown a folder with an exclamation mark, you will need to boot into disk mode and restore your iPod.
Instructions on that here:
http://support.apple.com/kb/HT1363
STEP 4: Tweaking
These are some settings i have enabled to make the iPod last longer on a charge and to reduce the number of hard drive spin-ups required using RockBox.
settings>general settings> playback settings>Anti-skip buffer> set it to 10 mins or max
settings>general settings> database>load to ram>yes
settings>general settings> system>disk>Directory cahe>yes
These help the iPod to optimize it's ram and to buffer more efficiently.
(these settings aren't necessary too complete the installation)
STEP 5: Extras
Adding a base Doom Wad, icons, fonts.
To add the font package:
Go to the zip file that you downloaded before. http://download.rockbox.org/daily/fonts/rockbox-fonts.zip
Enter the zip file and go into the .rockbox folder and then extract the fonts folder to the .rockbox directory on your iPod that you installed before. Overwrite them.
To play the doom game you need to install the base wad. Get it here. Remember! http://download.rockbox.org/useful/rockdoom.zip
Extract the doom folder in the zip file to the .rockbox directory of your iPod (this is getting very repetitive isn't it)
To play doom go to the main rockbox screen and click plugins>games>doom>start game
for more info on using RockBox have a look at the manual.
http://www.rockbox.org/manual.shtml
I hope this tutorial has helped you in some way!
Happy RockBoxing! Enjoy the open-source jukebox firmware.
I would like to thank the RockBox team for making such an awesome piece of software!
STEP 6: Uninstallation
If for some reason you are unsatisfied with RockBox, I will show you how to uninstall it from your iPod.
First, plug in your iPod to computer.
Load up ipodpatcher.exe
Enter U
ipodpatcher will take about 10-20 seconds and after it is done the bootloader of your iPod will be back the same way it was before the installation. (you cannot load rockbox anymore)
Navigate to the root directory of your iPod (the place where you put the .rockbox folder. usually E:\)
Delete .rockbox
Your done! your iPod no longer has RockBox.
Enter U
Delete .rockbox
45 Comments
ronaldf14 8 years ago
is there a rockbox version for Ipod nano 3rd gen???
WXB 8 years ago
The Apple support link for identifying your iPod incorrectly includes a right parenthesis at the end and returns an HTTP 404 Not Found status code. You can delete the paren to get it to work or use this URL that the old link redirects to: https://support.apple.com/en-us/HT204217
demango 12 years ago
tin701 12 years ago
Sparkythehappygirafe 15 years ago
tin701 15 years ago
mgikhnds 14 years ago
Rockbox is sooooo cool. I installed it and everything was fine. Then I did something really stupid and copied over the contents of a new theme to the Ipod replacing the originals.
I suspect this is not the way you're supposed to install themes, and now my Ipod won't boot up, even when pressing Menu+Play to hard reboot it. I have a 1st Gen Nano.
My computer does not recognise it when I plug it in the USB port, have I completely screwed it?
Take it easy guys keep up the good work.
tin701 14 years ago
Just do a hard reboot and as soon as you see the apple logo, press and hold play/pause and the centre button.
Then it should come up in disk mode, then you can plug it in and restore.
Try reading this article:
Zog666 14 years ago
I was goin to comment and ask what to do coz i accidently uninstalled the base.
Won't be making that mistake again!
Thanks so much for your help!
The great thing about Rockbox is that it opens the Ipod up to Blind and partially sighted people who have to rely on very expensive accessible players, shame when this is free!
Also, take that Itouch people! We can play videos as well. ;-P
Keep up the good work!
tin701 15 years ago
tin701 14 years ago
sorry about that
=D
Sparkythehappygirafe 14 years ago
crabsintrees 14 years ago
tin701 14 years ago
Crail 14 years ago
tin701 14 years ago
Crail 14 years ago
