Introduction: Install an After Market Android Unit for Nissan Elgrand E51
Install a new android 10 unit into a Nissan Elgrand can be quite time consuming if you don’t know what to do. This article aims to simply the process and give clarity to whoever wants to attempt to the project.
Android 10 unit from AliExpress
https://a.aliexpress.com/_dTq9w0G
ISO to Nissan 10pin 6pin harness
https://a.aliexpress.com/_d7Ijl6U
Nissan radio atena
https://a.aliexpress.com/_d6Ee7xW
Wiring connector
https://a.aliexpress.com/_d6bXQba
RCA splinter for subwoofer
https://a.aliexpress.com/_dYGjbUo
Facia
https://a.aliexpress.com/_dZJqoPK
Step 1: Take Apart Centre Console
Follow the instructions from this YouTube video
Step 2: Use ISO Harness and Wiring
use a nissan 10pin 6pin to ISO harness in between. However, the nissan did not provide a ground pin, you will need to connect the ground pin from the ISO harness to a screw to ground it.
in addition, the illumination pin from the ISO harness should be connected to the Illumination wire on the unit.
Step 3: Connect SWC Wires
there is a 16pin connector which was used on the factory unit for satellite signal, but it carries three wires for Steering Wheel Control (SWC). Once connected, all buttons on your steering work should work except pick up phone and a voice button.
use the video below as a guide, but for this android 10 unit, the SWC functions exist under Settings -> Car infortaiment -> SWC instead as an app shown in the video.
Step 4: Dry Run on the New Unit
Take off the brackets from the factory stereo unit and refit them on the new unit, they should be an exact fit. connect all the wires and test the unit, pay attention to GPS, bluetooth and wifi connectivity.
and insert the unit into position and screw the top two screws.
Step 5: Fit the After Market Facia
fitting the aftermarket facia is very straight forward. follow the steps below.
- screw on the A/C control buttons to the facia
- plugin the emergency indicator light button
- place the new unit into the 2-DIN opening, secure the two screws on the bottom holding together by a metal strip. at this point, the unit will appear a little loose.
- tidy up the wiring and connectors, and insert the unit along with facia into place, and secure the top/bottom eight screws
everything should be fitted properly by this point, and no loose point with the new unit.
