Introduction: Installed Gcc for W10 for Visual Studio Code
I hadnt a compiler in VSC for programming C/C++
So I needed to find a way like: https://www.wikihow.com/Run-C-Program-in-Command-Prompt
Step 1: Check If Gcc Is Installed
On W10 you can check if gcc is installed
C:\Windows\system32>gcc --version
Step 2: Install MINGW
If it can't be found you need to download mingw-get-setup.exe from https://sourceforge.net/projects/mingw/
also make sure when installing it to select "mingw32-base" and "mingw-gcc-g++."
Then you need to restart VSCode
