Introduction: Installing MQTT Broker(Mosquitto) on Raspberry Pi
In this instructables you will find how to install MQTT on Raspberry Pi. There are two methods to install mqtt, one is we directly connect keyboard mouse and monitor to a Pi , turn it on and go to the terminal of the raspberry pi and install it from there. Another method is to access Pi through a computer using putty(SSH) and logging into the root and installing, we have an instructable which mentions how to install putty and access Pi through a computer ,you can get it here .In this instructables we are following the second method. Both mqtt client(Pub/Sub Client) and broker( mosquitto) needs to be installed on Pi.
Step 1: Installation of the MQTT Broker on Raspberry Pi
To use the new repository you should first import the repository package signing key follow the below comman, the wget command is used to download single file and stores in a current directory.
wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
Then make the repository available to apt
cd /etc/apt/sources.list.d/
Enter the following
for wheezy
sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list
for jessie
to install the mqtt mosquitto for the raspberry pi follow the below steps use sudo before the command if not using root
sudo -i
The above command is not mandatory ,it is if you wish to use root or you will need to prefix each below command with sudo eg sudo apt-get update
The below command is used to update the source list
apt-get update
After updating type the following commands to install mosquitto broker as shown in the image 1.
apt-get install mosquitto
the above command is to install mqtt mosquitto broker.
Step 2: Installation of the MQTT Client on Raspberry Pi
After the installation of mqtt broker, install the mqtt client on raspberry pi.
The below shows the command to install mqtt mosquitto client this can be clearly seen in the image1 .
apt-get install mosquitto-clients
Step 3: Testing the Working of MQTT
After installing mqtt mosquitto broker and client the user need to test by creating the topic. Open two putty programs on windows, you can do this by clicking the putty.exe file and enter the host name and click to open do this twice so that two putty programs access Pi via ssh. Lets say putty1 and putty2 are open and connected to Pi via ssh for our convenient.
In putty1 window type the command with the topic name armtronix_mqtt this topic name can be anything, according to the convenience of the user .
mosquitto_sub –d –t armtronix_mqtt
As shown in the image 1 this will subscribe Pi to MQTT broker(which is runs on Pi) handling topic armtronix_mqtt.
In putty2 image 2 window type the following command with the same topic i.e armtronix_mqtt
mosquitto_pub –d –t armtronix_mqtt –m “Hello armtronix”
Now come to the window putty1, image 1 here you will be able to see the message
Hello armtronix
This concludes the that you are running the Mosquitto broker successfully.
Similarly here another case we have tested mosquitto_pub –d –t armtronix_mqtt –m “Test passed” will display Test passed as it is shown in image 1 and image 2.
Step 4: Testing MQTT From Another System
If you want to mqtt to connect through the network/internet from another system then you need to type the IP address of the host(Broker System, in our case its Raspberry Pi ) and you will be able to connect. In the image 3 it is shown that another computer from the LAN network has subscribed to the topic armtronix_mqtt in the window 1 using the command .Please note 192.168.1.10 is the raspberry pi ip address and may be different in your case.So you will need to enter following command as shown in the image 1 which refers to window 1.
mosquitto_sub -h 192.168.1.10 -t armtronix_mqtt
Now in the terminal window 2 we are publishing by entering the command as shown in the image 2
mosquitto_pub -h 192.168.1.10 -t armtronix_mqtt -m "Hi this is Armtronix_server"
Now in the window 1 we will be able to see the message Hi this is Armtronix_server as shown in the image 3
We hope the we have made it as clear as possible for other to understand the process of installing and testing Mqtt on Raspberry Pi .Thank you
Creating some other instructable- Installation of openHAB on Raspberry Pi and setting it to control the lights, fan and camera etc which will be updated shortly.
49 Comments
Question 2 years ago
Great tutorial - thanks! Is there a chance things have changed & no longer work or need a new configuration with the latest MQTT & Raspberry Pi OS? I'm using Raspberry Pi OS Bullseye & mosquitto version 2.0.11. I can use the publish and subscribe commands with localhost, but when I try an IP address or the name of my Pi I get an: Error: Connection refused. This was working on earlier mqtt & pi os releases. Thanks for your advice!
Answer 1 year ago
Had the same problem. I found there were some changes since mosquitto 2.0.2. See this article:
http://www.steves-internet-guide.com/install-mosqu...
Question 5 years ago on Step 3
When I get here: mosquitto_sub –d –t armtronix_mqtt
I receive an error: Connection refused.
I don't know where to go from here.
Answer 5 years ago
You probably did not start the mosquitto broker -- looks like that step may have been missed in the instructions.
In your terminal run `mosquitto`
Then in a new tab, ssh into the pi again and run the `mosquitto_sub -d -t foo` command to subscribe to the "foo" topic.
Then in a third terminal window ssh into the pi yet again and run `mosquitto_pub -t foo -m 'bar'`. You should see "bar" appear in the second terminal where you had originall subscribed to the "foo" topic.
Reply 2 years ago
really thanks!
Answer 4 years ago
The '-' character must e used. Apparently there is a long and short dash. See
https://unix.stackexchange.com/a/533275/182280
Reply 5 years ago
mosquitto_sub -h xxx.xxx.xxx.xxx -t armtronix_mqtt
Here xxx.xxx.xxx.xxx is you broker ip address
4 years ago
Thanx for this tutorial. Managed to get it installed, but 3 little comments:
- http://repo.mosquitto.org/debian/mosquitto-wheezy.... doestn't exist anymore. I went on the repo to see what is in it to change to the right file suitable for my configuration (http://repo.mosquitto.org/debian/mosquitto-buster....
- The "-" in "mosquitto_sub –d –t armtronix_mqtt" is the wrong one, so just copy pasting will give you an error, and you will be looking for problems where there is none
- idem for the " in the testline " mosquitto_pub –d –t armtronix_mqtt –m “Hello armtronix”
Other then that working like a charm! thank you for the explanation!
5 years ago on Step 4
I had trouble getting it to work on my old Raspberry Pi B (RPi B). The issue ended up being because I used the Raspian version "Stretch" and it having some dependencies that caused issues when installed on the older Raspberry Pi version. After I rebuilt the RPi B using "Jessie" instead of "Stretch" is worked straight away.
Reply 4 years ago
Good comment. My version of Raspian is Buster, so I had to perform a similar modification. When will instructables explain this, so that younger users will not hit this obstacle?
Tip 4 years ago
The publish / subscribe will fail because the short form of the dash '-' must be used:
mosquitto_sub -d -t armtronix_mqtt
For more details see: https://unix.stackexchange.com/a/533275/182280
When will instructables correct the error?
Tip 4 years ago on Step 1
sudo aptitude install mosquitto
Question 5 years ago on Step 4
hello,
I installed the MQTT on raspberry pi3 as my server but I can not connect to it through the MQTT from another pc on my network even though I was successful to send and receive messages on same server but not from another client on the same network any ideas of where to look the message I get is "connection failed!" thanks
Tip 5 years ago on Step 3
The command options are prefixed by something other(–) than a regular hyphen(-) & the quotes(”) you use are different to these (') which I need on my ssh connection. Otherwise thanks for a nice short explanation of what MQTT is and how to get this set up. Cheers :)
6 years ago
Stretch has replaced Jessie.
Trying to install MQTT under stretch I get:
AFter running this:
mkdir mosquitto
cd mosquitto/
wget http://repo.mosquitto.org/debian/mosquitto-repo.g...
sudo wget http://repo.mosquitto.org/debian/mosquitto-stretc...
sudo apt-get update
Then I made the manual entry:
pi@mqtt:~/Install-Programmes $ sudo apt install -y mosquitto
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mosquitto : Depends: libssl1.0.0 (>= 1.0.1) but it is not installable
Depends: libwebsockets3 (>= 1.2) but it is not installable
E: Unable to correct problems, you have held broken packages.
ANy help on this
Reply 5 years ago
I ran into the same problem on pi3. Here is what fixed the issue for me.
wget http://security.debian.org/debian-security/pool/u...
http://http.us.debian.org/debian/pool/main/o/opens...
sudo dpkg -i libwebsockets3_1.2.2-1_armel.deb
sudo dpkg -i libssl1.0.0_1.0.2l-1~bpo8+1_armhf.deb
sudo apt-get install mosquitto
Reply 5 years ago
reset your /etc/apt/sources.list file and typing those commands on your terminal:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get -y install mosquitto mosquitto-clients
Reply 6 years ago
use atpitude to install instead, it can override the dependency conflicts. done this twice now and it worked both times.
$ sudo aptitude install mosquitto
Reply 6 years ago
sudo aptitide install mosquitto did not solve it for me, same error, though eventually i got some options offered that seemed to install a package
Reply 6 years ago
Use this:
add (uncomment) deb-src http://archive.raspberrypi.org/debian/ stretch main ui
to raspi.list in /etc/apt/sources.list.d
apt-get install cmake uuid-dev
apt-get install libwebsockets-dev
apt-get install libssl1.0.2
apt-get install mosquitto mosquitto-clients
