Introduction: Installing Racheting Armrest Compenent for Honda Passport/Pilot/Ridgeline
The Sport models of the current gen models of the Honda Passport, Pilot and Ridgeline do not come standard with a ratcheting armrest. However, you can replace the static armrest bracket with a ratcheting bracket for the JJ Products aftermarket armrest product.
I bought the ratcheting extra wide armrest and needed to replace the attachment point (aka - bracket).
Ordered the part from Honda, arrived one day later... this was a 20 min job.
Ratchet set (to remove the old armrest)
Handheld drill with torx bit
Step 1: Unzip the Back "seam" of the Seat
You might need to pull the extended part of the zipper out from behind the lower plastic sheath
Step 2: Remove the Armest to Expose the Static "UP & DOWN" Position Armrest Bracket
Once unzipped, remove the current armrest and pull the fabric cover over the exposed hardware - push towards the front of the seat. Dont worry, the fabric is form fitting and will slide back into place when you're finished
Step 3: Look for the 2 Screw-holes Attaching the Static Bracket to the Seat Sub-frame
You can either push the foam material to side or pull it to the forward facing part of the seat like with the seat cover fabric/leather
Step 4: Unscrew the 2 Screws
Be sure to keep these, the ratchet bracket does not come with replacement screws
Step 5: Remove the Static Bracket
Step 6: Attach the Ratchet Bracket
On the back of the ratchet bracket, there are plastic 2 placement guide-"rods". In the attached pic, see at top and bottom if the white plastic component.
The two guides are designed to match to corresponding holes/die-cuts so that the rachet bracket is oriented correctly. This is a nice fool-proof design feature.
Step 7: Screw-on the Rachet Bracket
Screw-in the old screws from the static-bracket and pull the foam and seat material back onto its previous position.
Re-zip the back seam, tuck it back into the plastic sheathing and add the new ratcheting armrest using the instructions from the JJ Products.net
