Introduction: Installing Freebasic on (Debian) Linux.
Freebasic is like Qbasic. Most all of the instructables we do that involve programming use Freebasic. One think I like about it is the ease of programming the parallel and other ports on the computer. There are certainly lots of other programming languages you could use (i.e. http://computothought.wordpress.com/2010/04/06/freedom-of-assembly/), but there have been so many programs written for qbasic, you just hate not to be able to use them.
Freebasic is a derivative of the Beginners All Purpose Instruction Code aka Basic. BASIC (standing for Beginner's All Purpose Symbolic Instruction Code) was written (invented) in 1963, at Dartmouth College, by mathematicians John George Kemeny and Tom Kurtzas as a teaching tool for undergraduates. BASIC has been one of the most commonly used computer programming languages, a simple computer language considered an easy step for students to learn before more powerful languages such as FORTRAN. Ironically I learned Fortran before I ever new about Basic. Today, probably the web based languages such as Javascript, Python, or C might be more in line with what people are using.
You may want to install the c compiler first, if you have not already done so.
$ sudo apt-get install build-essential
Step 1: Manual Install
Normally I only try to use software from the Linux, but this is an exception. You could use Mono, but there are too many legal and other issues involved.
Install Freebasic: on newer system libfreebasic is not needed. now version: 1.00.0
$ sudo apt-get install libfreebasic libxext-dev libncurses5-dev libx11-dev libxpm-dev libxrandr-dev libstdc++6-4.4-dev
Go to sourceforge.net and download FreeBASIC-0.24.0-linux.tar.gz
$ tar zxvf FreeBASIC-0.24.0-linux.tar.gz
$ cd FreeBASIC-
1.00.0
-linux
$ chmod +x install.sh
$ sudo ./install.sh -i
Write a program:
$ vim helloworld.bas
[code]
print "Hello world! "
[/code]
Compile it:
$ fbc -lang qb helloworld.bas
Run it:
$ ./helloworld
Hello World!
Note According to http://www.freebasic.net/forum/viewtopic.php?f=17&p=189357 Freebasic is now available for the ARM. There are some download links on the page. Since the Freebasic website soes not include them, sue with caution.
Step 2: Gui Test.
roids.bas:
[code]
' ÜÛÛÛÛÜ ÜÛÛÛÛÛÛÜ ÛÛÛÛÛÛÛÛ ÛÛÛÛÛÛÛÛÛ ÛÛÛÛÛÛÜ ÜÛÛÛÛÛÜ ÛÛ ÛÛÛÛÛÛÜ ÜÛÛÛÛÛÛÜ
'ÛÛ ÛÛ ÛÛß ßßß ÛÛ ÛÛ ÛÛ ßÛÛ ÛÛß ßÛÛ ÛÛ ÛÛ ßÛÛ ÛÛß ßßß
'ÛÛ ÛÛ ßÛÛÜ ÛÛ ÛÛ ÛÛ ÜÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ßÛÛÜ
'ÛÛÛÛÛÛÛÛ ßÛÛÜ ÛÛ ÛÛÛÛÛÛ ÛÛÛÛÛÛß ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ßÛÛÜ
'ÛÛ ÛÛ ßÛÛÜ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ßÛÛÜ
'ÛÛ ÛÛ ÛÛÜ ÜÛÛ ÛÛ ÛÛ ÛÛ ÛÛ ÛÛÜ ÜÛÛ ÛÛ ÛÛ ÜÛÛ ÛÛÜ ÜÛÛ
'ÛÛ ÛÛ ßÛÛÛÛß ÛÛ ÛÛÛÛÛÛÛÛÛ ÛÛ ÛÛ ßÛÛÛÛÛß ÛÛ ÛÛÛÛÛÛß ßÛÛÛÛß
'This is a one person game. The object is to shoot the falling asteroids and
'keep them from hitting the surface. Use the left and right arrow keys to
'move your gun and the up key to fire. The "P" button pauses the game, and
'the "Q" button ends it. When a game is paused, hit space to make it run
'again. Scoring is based on the level you're on. The higher the level, the
'more points for hit asteroids, and the less points taken away for missed
'asteroids. While you play, you may notice the screen flickering badly, or
'the action to fast. To correct this, make the number after Flicker.Control
'(shown below) bigger. If the game goes too slow, make the number smaller.
Flicker.Control = 500 ' Now press "F5" to play.
SCREEN 7 '320 X 200 resolution
RANDOMIZE TIMER
movement = 0
playagain:
CLS
LOCATE 12, 1
COLOR 15
INPUT ; "What level do you want to start at"; level
LOCATE 12, 1
PRINT " "
gun = 165
missile.x = -5000
missile.y = 5000
totalhit = 0
misses = 0
totaldropped = 0
newasteroid:
asteroid.x = 319 * RND + 1
asteroid.y = 1
totaldropped = totaldropped + 1
a:
COLOR 0
WHILE movement = 1
LINE (gun2 - 20, 170)-(gun2 + 20, 170)
LINE (gun2, 155)-(gun2 - 20, 170)
LINE (gun2, 155)-(gun2 + 20, 170)
LINE (gun2 - 3, 147)-(gun2 + 3, 170), , BF
movement = 0
WEND
COLOR 15
LINE (gun - 20, 170)-(gun + 20, 170)
LINE (gun, 155)-(gun - 20, 170)
LINE (gun, 155)-(gun + 20, 170)
LINE (gun - 3, 147)-(gun + 3, 170), , BF
LINE (asteroid.x - 10, asteroid.y - 6)-(asteroid.x + 10, asteroid.y + 6), 6, BF
CIRCLE (missile.x, missile.y), 3, 12
LINE (1, 171)-(319, 171), 9
FOR count = 1 TO Flicker.Control
NEXT count
asteroid.x2 = asteroid.x
asteroid.y2 = asteroid.y
missile.x2 = missile.x
missile.y2 = missile.y
COLOR 0
LINE (asteroid.x2 - 10, asteroid.y2 - 6)-(asteroid.x2 + 10, asteroid.y2 + 6), 0, BF
CIRCLE (missile.x2, missile.y2), 3, 0
LOCATE 23, 1
COLOR 9
PRINT "Shot:"; totalhit
LOCATE 23, 11
PRINT "Level:"; level
LOCATE 23, 21
PRINT "Score:"; score
missile.y = missile.y - 5
IF missile.y < 1 THEN
missile.y = 5000
END IF
asteroid.y = asteroid.y + level * .75
IF asteroid.y > 170 THEN
CIRCLE (asteroid.x, asteroid.y), 30, 14
CIRCLE (asteroid.x, asteroid.y), 30, 0
misses = misses + 1
IF misses = 10 THEN
GOTO gameover
END IF
score = score - INT(10 / level)
GOTO newasteroid
END IF
IF missile.x - 3 < asteroid.x + 10 AND missile.x + 3 > asteroid.x - 10 AND missile.y + 3 < asteroid.y + 6 THEN
totalhit = totalhit + 1
IF totalhit / 10 = INT(totalhit / 10) THEN
level = level + 1
misses = 0
END IF
score = score + 10 * level
FOR ctr = 1 TO 7
radius = 15 * RND + 5
offset.x = 40 * RND - 20
offset.y = 40 * RND - 20
circlecolor = 16 * RND
CIRCLE (asteroid.x + offset.x, asteroid.y + offset.y), radius, circlecolor
FOR ctr2 = 1 TO 50
NEXT ctr2
CIRCLE (asteroid.x + offset.x, asteroid.y + offset.y), radius, 0
NEXT ctr
missile.y = 5000
GOTO newasteroid
END IF
move$ = INKEY$
SELECT CASE move$
CASE CHR$(0) + "K"
gun2 = gun
gun = gun - 5
movement = 1
CASE CHR$(0) + "M"
gun2 = gun
gun = gun + 5
movement = 1
CASE CHR$(0) + "H"
missile.x = gun
missile.y = 147
CASE "q"
GOTO quit
CASE "p"
COLOR 15
LOCATE 12, 4
PRINT "Game Paused Hit Space to continue"
startpause:
a$ = INKEY$
SELECT CASE a$
CASE " "
LOCATE 12, 4
PRINT " "
GOTO endpause
END SELECT
GOTO startpause
END SELECT
endpause:
GOTO a
gameover:
LOCATE 23, 1
COLOR 9
LOCATE 23, 11
LOCATE 23, 21
COLOR 15
COLOR 4
LOCATE 12, 1
PRINT "E O"
LOCATE 12, 1
PRINT "ME OV"
LOCATE 12, 1
PRINT "AME OVE"
LOCATE 12, 1
PRINT "GAME OVER"
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
LOCATE 12, 1
PRINT " GAME OVER "
FOR ctr = 1 TO 500
NEXT ctr
LOCATE 13, 13
PRINT "Play Again? y/n"
playagain.y.n:
y.n$ = INKEY$
SELECT CASE y.n$
CASE "n"
GOTO quit
CASE "y"
GOTO playagain
END SELECT
GOTO playagain.y.n
quit:
[/code]
$ fbc -lang qb roids.bas
Step 3: Other Freebasic Instructables.
A few other instructables you might be interested in that could be used with free basic.
https://www.instructables.com/id/DIY-computer-spreadsheet-program-template/
https://www.instructables.com/id/The-Oracle/
https://www.instructables.com/id/Simple-adventure-game/
https://www.instructables.com/id/Predict-the-future-for-someone/
https://www.instructables.com/id/No-solder-parallel-port-break-out/
https://www.instructables.com/id/Linux-beginning-home-automation-on-a-server/
https://www.instructables.com/id/Home-Automation-MSWindows-XP/
Step 4: Dosbox to Access Other Basics.
Gwbasic generally saves code is a special format. You can load those files in and then save them in ascii or text.
Step 5: QB64
Qb45 (www.qb64.net) is another basic compiler. It is available for the major platforms. (instructions for Ubuntu 12.04 is at: http://www.as2.com/pdf/QB64-install-manual-on-Precise-Pangolin.pdf
