Introduction: Intel® Edison Hands-on Day 6: Sensor Lamp
In this section we will try to make a sensor lamp. When
someone passes by the sensor lamp, the LED will be automatically on. Of course, it will be off if nobody is around. We select PIR motion sensor in this example. It allows you to detect whether someone has moved in or out of the sensors range. It is a good choice for April Fools~~
Tools required
Step 1: Connection
PIR Motion Sensor → Digital Pin 2
Digital piranha LED light module → Digital Pin 13
Step 2: Coding
int sensorPin = 2; // PIR Motion Sensor Pin
int ledPin = 13; //LED Pin int sensorState = 0; //Store the PIR Motion Sensor State void setup() { pinMode(ledPin, OUTPUT); //LED is an output device pinMode(sensorPin, INPUT); // The Sensor is an input device } void loop(){ sensorState = digitalRead(sensorPin); //Read the sensor state if (sensorState == HIGH) { //If the sensor state is HIGH, turn on the LED digitalWrite(ledPin, HIGH); } else { //otherwise turn off the LED digitalWrite(ledPin, LOW); } }
After uploading the sketch, trying to go away from the sensor and wait a moment. Pay attention to the LED and it will be off. If you get close to the sensor, the LED will be on automatically.
Step 3: Principle(Digital Input—Digital Output)
There is three parts of the device, input part, controlling part and output part. PIR Motion Sensor is the input part. Edison is the controlling part. LED is the output part PIR Motion Sensor is a digital sensor, and LED is also a digital device.
