Intel® Edison Hands-on Day 8: Guardian of Eden
Intro: Intel® Edison Hands-on Day 8: Guardian of Eden
Would you like to provide a comfortable environment for your plants and flowers in your garden? Are they thirsty for the time being? Through a temperature sensor, a soil humidity sensor, and a LCD display, you can easily get the state of your soil.
Component Required
STEP 1: Connection
- LCD Keypad Shield for Arduino → Plug onto the Intel® Edison with Arduino Breakout Kit
- LM35 Analog Linear Temperature Sensor → Analog Pin 1 (note the first left connection in the bottom right corner. Analog Pin 0 is occupied by keyboard)
- Soil Moisture Sensor → Analog Pin 2
STEP 2: Coding
After uploading the sketch, the LCD will show the temperature and humidity, as well as the soil humidity condition.
// Guardian of Eden
#include
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // Initiate the LCD display with the numbers of the interface pins
int TemperaturePin=A1; //The pin number of the temperature sensor
int HumidityPin=A2; //The pin number of the humidity sensor
void setup() {
lcd.begin(16, 2); // set up the LCD's number of columns and rows
void loop() {
int temperatureValue; //store the analog value from temperature sensor
int humidityValue; //store the analog value from humidity sensor
int temperature; //store the real temperature.
temperatureValue=analogRead(TemperaturePin); //read the temperature sensor
humidityValue=analogRead(HumidityPin); //read the humidity sensor
temperature=(500 * temperatureValue) /1024; //Convert the analog value to real temperature.
//LCD shows the temperature
lcd.setCursor(0, 0); // set the cursor to column 0, line 0
lcd.print("T:");
lcd.print(temperature);
lcd.print("C");
//LCD shows the humidity of the soil
lcd.setCursor(0, 6); // set the cursor to column 6, line 0
lcd.print("H:");
lcd.print(humidityValue);
//Show the situation of the soil
lcd.setCursor(1, 0); // set the cursor to column 0, line 1
if (humidityValue<300) {
lcd.print("Soil: Dry");
else if (humidityValue>=300 && humidityValue<700){
lcd.print("Soil: Humid");
else{
lcd.print("Soil: Water")
delay(500);
3 Comments
MallikarjunB 9 years ago
This Code has errors!
Pls upload correct code
jman 31 9 years ago
Thanks for sharing your work with the edison! Have you tried it with a web cam?
Regards,
Jeremy
seamster 9 years ago
Very nice. Thanks for sharing this!
