Introduction: Interfacing LED Matrix With Processing
In the last tutorial, I explained how to make your first PCB ever Step by step
if you didn't see the last tutorial I recommend taking a look
https://www.instructables.com/LED-Matrix-PCB-Full-Beginner-Tutorial/
Because we will go throw the last step in the last tutorial
Processing Software
Step 1: Arduino Code
Arduino Code
we need to Edit our Arduino Code so Follow up on the instructions
- open **Arduino IDE** comment and and uncomment lines
- and Then Upload the code to the microcontroller By **Sketch >> Upload Using Programmer**
Step 2: Processing
Download Processing Here [Here](https://processing.org/download/)
- Complete the missing codes
- You Need To Edit the button and change its orientation I will leave the Edited Code Down Here
import processing.serial.*;
Serial myserial;
int data = 0;
boolean led_1 = false;
boolean led_2 = false;
boolean led_3 = false;
boolean led_4 = false;
boolean led_5 = false;
boolean led_6 = false;
int bit_1 = 0;
int bit_2 = 0;
int bit_3 = 0;
int bit_4 = 0;
int bit_5 = 0;
int bit_6 = 0;
int offsetx = 150;
int offsety = 125;
int x1 = 50;
int y1 = 50;
int x2 = x1 + offsetx;
int y2 = y1;
int x3 = x2 + offsetx;
int y3 = y2;
int x4 = 50;
int y4 = y1 + offsety;
int x5 = x4 + offsetx;
int y5 = y4;
int x6 = x5 + offsetx;
int y6 = y5;
int x7 = x5;
int y7 = y6 + offsety;
int w = 100;
int h = 75;
void setup() {
size(500, 400);
// you may need to edit this part to choose the correct serial port TODO: make sure the correct serial port is chose [0] or [1] ...
String myPort = Serial.list()[1];
myserial = new Serial(this, myPort, 9600);
void draw() {
if (led_1)
fill(255);
rect(x1,y1,w,h);
else
fill(100);
rect(x1,y1,w,h);
if (led_2)
fill(255);
rect(x4,y4,w,h);
else
fill(100);
rect(x4,y4,w,h);
if (led_3)
fill(255);
rect(x2,y2,w,h);
else
fill(100);
rect(x2,y2,w,h);
if (led_4)
fill(255);
rect(x5,y5,w,h);
else
fill(100);
rect(x5,y5,w,h);
if (led_5)
fill(255);
rect(x3,y3,w,h);
else
fill(100);
rect(x3,y3,w,h);
if (led_6)
fill(255);
rect(x6,y6,w,h);
else
fill(100);
rect(x6,y6,w,h);
fill(50);
rect(x7, y7, w, h);
// When the mouse is pressed, the state of the button is toggled.
void mousePressed() {
if (mouseX > x1 && mouseX < x1+w && mouseY > y1 && mouseY < y1+h) {
led_1 = !led_1;
bit_1 = bit_1 ^ 1;
if (mouseX > x4 && mouseX < x4+w && mouseY > y4 && mouseY < y4+h) {
led_2 = !led_2;
bit_2 = bit_2 ^ 1;
if (mouseX > x2 && mouseX < x2+w && mouseY > y2 && mouseY < y2+h) {
led_3 = !led_3;
bit_3 = bit_3 ^ 1;
if (mouseX > x5 && mouseX < x5+w && mouseY > y5 && mouseY < y5+h) {
led_4 = !led_4;
bit_4 = bit_4 ^ 1;
if (mouseX > x3 && mouseX < x3+w && mouseY > y3 && mouseY < y3+h) {
led_5 = !led_5;
bit_5 = bit_5 ^ 1;
if (mouseX > x6 && mouseX < x6+w && mouseY > y6 && mouseY < y6+h) {
led_6 = !led_6;
bit_6 = bit_6 ^ 1;
if (mouseX > x7 && mouseX < x7+w && mouseY > y7 && mouseY < y7+h) {
data = bit_6<<6 | bit_5<<5 | bit_4<<4 | bit_3<<3 | bit_2<<2 | bit_1<<1;
myserial.write(data);
Step 3: Testing
And now for the truth, we will Run the code and see the results
Step 4: Issues & Solutions
The first Issue may face you is that you will find the Error Like that
to solve this Error you should change the file name of the file from **Interfacing** to any name
