Introduction: Interfacing Servo Motor With ESP32
Servo Motors are one of the most important actuators in the realm of robotics being applied in use cases from RC planes to automated door locks. Therefore, this second module of the ESP32 lesson, we will cover how to control servo motors.
Interfacing a servo motor to the ESP32 is very difficult compared to an Arduino, since it does not support analogWrite(). However, it uses various frequencies and timers, allowing the all digital pins to be used as PWM pins as well send signals significantly faster than any Arduino!!!
Step 1: Tools and Materials
- ESP32 Development Board
- Servo Motor
- 3 pieces of male-to-male jumper wires
- Breadboard
Step 2: Circuitry
- Connect the signal pin of the servo, shown as the white wire, to pin D2 on the ESP32 board.
- Connect the VCC pin of the servo, shown as the red wire, to the 3.3V pin on the ESP32 board.
- Finally, connect the ground pin of the servo, shown as the blackwire, to the GND pin on the ESP32 board.
Step 3: Coding
#define COUNT_LOW 0
#define COUNT_HIGH 8888
#define TIMER_WIDTH 16
#include "esp32-hal-ledc.h"
void setup() { ledcSetup(1, 50, TIMER_WIDTH); // channel 1, 50 Hz, 16-bit width ledcAttachPin(2, 1); // GPIO 22 assigned to channel 1 }
void loop() { for (int i=COUNT_LOW ; i < COUNT_HIGH ; i=i+100) { ledcWrite(1, i); // sweep servo 1 delay(50); } }
Step 4: Demonstration Video
The servo motions follows as programmed going from the minimum to maximum at much faster speeds relative to an Arduino or ESP8266.
Makerspace Contest 2017
7 Comments
Question 1 year ago
I have used servomotor SG90 with esp32, i have done the connections and code, as per the instructions. After compliation there's no error and i have uploaded into esp32. But my motor is working at all,
i have used the checkind servo motor with Arduino, it is working. But with Esp32 the servo motor doesn't rotate or motor also doesn't make any movement.
I've tried powering the servo from external source, keeping common ground. But still not working.
Sometimes i don't know how servomotor automatically makes to and fro rotation and gets heated.
Do you know, where i am facing the issue
2 years ago
Hello,
could you please explain to me where the 8888 value comes from?
thanks in advance.
3 years ago
greetings TechMartian,
i am accustomed to arduino, mega2560 environment, so please excuse my ignorance
because i have just two questions:
00) you have postedover 18 months ago: "The servo library cannot be used
and is not supported in the ESP32."
is this still true??
01) have you tried servo with high torque that needed drivers like vnh2sp30/l298n ???
thanks for your time
3 years ago
I use the esp32 to control a servo motor using the uPyCraft IDE, I find it easier to use and for beginners it would be ideal. Here is my code using uPyCraft IDE:
from machine import Pin, PWM
import time
servo = PWM(Pin(4), freq=50, duty=512)
while True:
for d in range(51,115):
servo.duty(51)
time.sleep(2)
servo.duty(112)
time.sleep(2)
servo.duty(51)
time.sleep(2)
servo.duty(21)
time.sleep(2)
def pwm():
pwm.duty(d)
time.sleep(0.01)
continue
Enjoy!!
4 years ago
Very interesting.
As a newbie it took me some time to find out that the right pin to use is IO2 (not the IO22 in the comment of the sketch nor the IO0 in one of the diagrams). Now it works really well.
Thanks!.
5 years ago
Nice work. This will be handy for my future projects.
Couldn't you just use the servo library to call a specific degree of rotation? I've used one of the servo libraries with a NodeMCU Lolin V3 board based on the ESP8266 chip with pin D2 for signal and 3.3v for servo power without any issues. Does the Arduino IDE have Bluetooth capability with the ESP32? I thought the ESP32 has a bluetooth transceiver built in. How much current can does the ESP32 board output for VCC and GPIO?
Sorry to ask so many questions!
Reply 5 years ago
That's one of the most important reasons why I posted this on Instructables. The servo library cannot be used and is not supported in the ESP32. But since we're using timers, it makes it super fast! I was hoping it'd be featured to more people would know about this board it is so awesome but also have some big differences from the ESP8266 as shown.
It does have bluetooth. I'm going to write a bluetooth module soon actually, so stay tuned!
I haven't had problems with the current and voltage even with a 3.3V power which was very surprising to me. The max current output it 12mA.
I hope I've answered your questions.
