Introduction: Intermediate Batch Command List
Mode con Lines ( Sets the height of the command prompt.)
Example: Sets the height of the command prompt to one-hundred.
Mode con Lines=100
Mode con Cols ( Sets the width of the command prompt.)
Example: Sets the command prompt to one-hundred an twenty.)
Mode con Cols=120
%Random% ( A random number is displayed when echoed.)
Example: Displays a random number such as 16454 or 68332, could be anything.)
Echo %random%
Lss ( Less than.)
Example: If 9 is less than 8 it displays "My life is a lie", but it's not so it won't display it.
If 9 lss 8 Echo My life is a lie
Gtr ( Greater than.)
Example: If 9 is greater than 8 it displays "Oh, good" and it is so it will display it.
If 9 Gtr 8 Echo Oh, good
Equ ( Equal to.)
Example: If 10 is equal to 5 + 5 it displays "Math" on the command prompt.
Set /a num=5 + 5 If 10 Equ %num% Echo Math
If Exist ( If a file exist on your computer.)
Example: If Google Chrome is on your computer it displays "Google" on the command prompt.
If Exist Chrome.exe Echo Google
If not Exist (Self explanatory.)
Example: If Google Chrome is not on tour computer it displays "Internet Explorer now?" on the command prompt.
If not Exist Chrome.exe Echo Internet explorer now?
>> ( Inputs things into a file.)
Example: Makes a text document called "Hello" on your computer and writes "Hello" in it with out displaying "Echo"
Echo Hello >> Hello.txt
>> nul ( Inputs stuff into nothing.)
Example: Pauses the Batch file until a key is pressed but does not display anything and does not make a file.
Pause >> nul
Call ( Outputs stuff on to the command prompt.)
Example: Say you have a batch file called "Greeting.bat" and it has the command "Echo Hello" in it. This takes that command and uses it on the batch file you were using at the time and displays "Hello"
Call Greeting.bat
Timeout /t ( Makes a delay.)
Example: Delays the Batch file for five seconds or until you press a key and displays: "Waiting for 5 seconds, press a key to continue ..."
Timeout /t 5
/Nobreak ( Doesn't let you press a key to continue.)
Example: Delays the Batch file five seconds, does not skip the delay when you press a key, and displays "Waiting for f seconds, press CTRL+C to quit ...". If you press Ctrl C the Batch file will close.
Timeout /t 5 /Nobreak
Tree ( Displays tree graph of all the files on your computer.)
Example: Yeah, look above this there's an explanation.
Tree
