Introduction: Interrupts With 8051
- An interrupt is an external or internal event that interrupts the microcontroller to inform it that a device needs its service.
- Interrupts vs. Polling
- A single microcontroller can serve several devices.
- There are two ways to do that: –
- Interrupts
- Polling.
- The program which is associated with the interrupt is called the interrupt service routine (ISR) or interrupt handler.
Step 1: Steps in Executing an Interrupt:
- Finish current instruction and saves the PC on stack.
- Jumps to a fixed location in memory depend on type of interrupt
- Starts to execute the interrupt service routine until RETI (return from interrupt)
- Upon executing the RETI the microcontroller returns to the place where it was interrupted. Get pop PC from stack
Step 2: Interrupt Sources:
Original 8051 has 6 sources of interrupts
1. Reset
2. Timer 0 overflow
3. Timer 1 overflow
4. External Interrupt 0
5. External Interrupt 1
6. Serial Port
Step 3: Interrupt Vectors:
Each interrupt has a specific place in code memory where program execution (interrupt service routine) begins.
External Interrupt 0: 0003h
Timer 0 overflow: 000Bh
External Interrupt 1: 0013h
Timer 1 overflow: 001Bh
Serial: 0023h
Step 4: Interrupt Enable (IE) Register:
• All interrupt are disabled after reset
• We can enable and disable them by IE
Step 5: Interrupt Priorities:
• What if two interrupt sources interrupt at the same time?
• The interrupt with the highest PRIORITY gets serviced first. • All interrupts have a power on default priority order.
1. External interrupt 0 (INT0)
2. Timer interrupt0 (TF0)
3. External interrupt 1 (INT1)
4. Timer interrupt1 (TF1)
5. Serial communication (RI+TI) •
Priority can also be set to “high” or “low” by IP reg.
Step 6: Interrupt Priorities (IP) Register:
IP.7: reserved
IP.6: reserved
IP.5: timer 2 interrupt priority bit(8052 only)
IP.4: serial port interrupt priority bit
IP.3: timer 1 interrupt priority bit
IP.2: external interrupt 1 priority bit
IP.1: timer 0 interrupt priority bit
IP.0: external interrupt 0 priority bit
Step 7: External Interrupt Example: (INT0):
Simulation interrupt is given in above.
C Code of External interrupt (INT0):
Step 8:
Any Query related Embedded System , IOT and Raspberry PI go to My Blog:
