Introduction: Intro to Wood Burning
This doesn't go into to much detail, but it will show you whether or not you will enjoy wood burning or if it isn't for you. Its a cheap way to decorate a room. and it is environmentally friendly because it doesn't require shipping and is made from natural materials such as wood.
you can get a wood burning kit at wal-mart, micheals, target or any store like these. or if your lucky you can pick one up for cheap at a flea market (make sure its in good shape becaus eyou don't want sparks flying everywhere). i got a few peices of wood with my kit but i bought most at Micheals. You can get small plaques at wal-mart and target also. (sunkist is also available at wal-mart.). Don't limit yourself to just plaques and the like. you can burn anything thats wood, such as a porch swing, a bench, a box, a carving, or a frame. Start out simple though, you don't want to stress your self out and then get so down on yourself that you don't want to try it any more. It is tough and takes patience and time so don't rush it but it is worth it when you see it everyday and know that you put your soul into it unlike if you just went to the store and bought a painting.
Step 1: Gathering Suplies
for a simple wood burning, you will need a wood burner, a tip (preferably a multi-tip for beginners), a peice of wood that you want to engrave/burn, and a safe surface to set the burner down on while cooling. this is often overlooked andresults in fire damage (don't be an idiot and burn down the neighborhood). For this i used a ceramic coffee cup.
Step 2: The Burning
you need to have an idea picked out before you start wood burning. woodburning, like making a sculpture, is unforgiving. if you mess up you have to start over or cover it up. wood burning requiers a steady hand and patience. you can't rush it, some more complex wood burnings take dayse on end to complete. if you don't have either of these skills, wood burning will not work out for you.
start with the words (if you want it to have any). then add in pictures or a back ground here are two of the more simple ones i have done.
Step 3: The Burning: Step 2
you want to draw out before hand what you will be burning because, as i said, you can't mess up. if you don't have much faith in yourself you can draw exactly how you want it to look and just place the picture over the wood and poke in dots. then its just a matter of connecting the dots. for your first wood burning i would suggest this. if its an object that is in front of you and not drawn, it helps to have it in front of you.
Step 4: Finished
its hard to tell people what to do because wood burning is an art that you have to create yourself. when you are done either hang up the wood burning or prop it up. then sit back and enjoy your homemade artwork. here are some pictures of a few of my other wood burnings.
