Introduction: Solar Plane
Introduction:
This instructable will show you how to create a solar powered plane. This project was done at Newman Smith High School (Carrollton-Farmers Branch Independent School District [CFBISD]) in Carrollton, Texas and was sponsored by the Texas A&M University Society of Flight Test Engineers. We received most of the needed parts from Texas A&M University and built the plane for the High School Solar Plane Competition on May 25, 2013. The project is not for the beginner as it gets a bit complicated. Skills that you will need include soldering skills, plane building skills, monokoting skills, and general R/C plane knowledge. Our team ended up with the Most Creative award and 2nd place in Endurance.
Special Thanks to Texas A&M University, Newman Smith High School Teachers and Principal & the DIY Drones Community (http://diydrones.com/forum/topics/solar-powered-plane).
Below are some pictures of the completed project. The next step will be the list of materials needed.
Also included below is the link for build basics and aircraft aerodynamics- there are two PowerPoints included by Texas A&M University. If you are going to do the project, printing out these two PowerPoints will help you immensely. However, please take note that all the cells must be in series, not in parallel as one of the PowerPoint presentations describes.
https://drive.google.com/folderview?id=0B_bYmGJ0v1Ncb283TF8tWXF6ZWc&usp=sharing
Want to see more photos? PM me and I'll give you a link.
UPDATE: 03/31/2014: Research Paper now included.
Step 1: Materials
Materials Needed:
Glider (we used the Gentle Lady)
Monokote (We ended up using about 3 rolls- two for the 8 foot wing [bottom] & body of the plane and another clear roll for the panels)
3x6 Solar Panels
Tabbing Wire
Bus Wire
Normal Wire
Micro Servos
Push Rods
Nylon Control Horns
Propeller
Li-Po Battery
ESC (Electronic Speed Controller)
Charger
Connectors (for Wires)
Receiver
Propeller
Electric Motor
CA Glue
Heat Shrink Tubing
Sewing String
Pairing Connector (depends on your transmitter/receiver)
Nuts (for balancing wing)
Balsa Wood Sheets (optional- depends on how big your wing is)
Tools:
Soldering Iron
Flux
Solder
Hobby Knife and extra blades
Heat Gun
Sealing Iron
Large Table
Sand Paper
Drill
Wire Cutter
Digital Multi-Meter
First Aid Kit
Step 2: Building the Wing
To begin the project, start by building the wing. The wing is where the panels will go on. Depending on what glider/plane kit you use, you may want to do it differently. We extended our two meter wing span to make it 8 feet to fit 22 panels in-between the ribs. The other teams that we competed with did not do so this way. They put the panels directly on the wings and did not extend the wing span. By extending the wing span and putting the panels in between, we used less ribs and made the wing more fragile, but it paid off and did not break because we did a pretty good job of reinforcing it.
To extend our wing, we cut out extra ribs from some balsas wood and duplicated the middle of the wing to extend it.
Follow the plans provided with your kit and build the wing. Extend the wing from the center if necessary.
Step 3: Solar Panels
Solar Panels: something that is a pain in the butt to install.
These solar panels were about as fragile as anything we had ever handled before. Rigid and inflexible, we broke about half of them.
Handling them with the uttermost care is very important to avoid damage to them. Some cracks are okay, it just depends on where they are located and how they broke. Searching up how solar panels work, how to cut them, and how to tab them really helps.
Some background information: The shiny blue side of the panel is negative. The bottom grey side is positive. To connect in series, connect the top tabbing wire to the bottom tabbing wire. There is more information in the PowerPoint.
After tabbing the cells, CA glue them onto the wing in-between the ribs. After doing so, then connect them in series carefully with the soldering iron, making sure to not hurt yourself.
The bus wires go at the end of the panels and are connected to a wire that leads to the middle of the wing from either side.
Step 4: Fuselage, Monokote & Electronics
Building the fuselage
The construction of the fuselage is not very difficult. Follow the instructions on the airplane plan provided. Wiring on the other hand may be more difficult. If you extend the wing, the CG on the plane may shift and you might have to do some minor modifications on servo placement. Heat shrink all electrical components to avoid any short circuits.
Monokote
Monokoting is not hard either. Use youtube videos to learn how to do it. Make sure when you are monokoting the wing, do the bottom first and then the top and make sure you curve the monotkote over to maintain a good airfoil and reduce any drag. You want to have as much laminar flow as possible. Make sure to use clear monokote for the top of the wing so the solar panels can charge. Cut and Iron the monokote on the wing, then blow it with the heat gun so it contracts and creates a tight wrap around the skeleton of the wing.
Wiring & Electronics
Follow the PowerPoints provided and you should be fine. Put the Nylon control horns where they belong and wrap them in tape so they don't fall off in flight.
Step 5: Testing Electronic Parts
To test the solar panels, plug them all into the charger where they belong and bring it outside to test on a sunny day. Plug the DMM into the output and measure the voltage. The charger that we used only started charging when the voltage was greater than 12 volts.
To test the other parts, pair the receiver and the transmitter together. Depending on which brand on transmitter you use, you may need a pairing plug.
Step 6: Test Flying
Bring the plane to an airfield and find an experienced pilot to fly the plane. That person will give you further instruction on how to modify the plane to give it better flight. For us, we needed to reinforce the elevator and rudder. We accomplished that with duct tape.
Step 7: Conclusion
The Solar Plane project is an amazing starting point to getting into green energy, R/C, planes, electronics, aerospace, or just about anything else. As for our team, we had an amazing four person group plus our amazing teacher. If you're in a team, make some team shirts, it boosts morale and on competition day, everyone knows who you are.
We ended up with 2nd in endurance because the charger wouldn't charge below 12 volts and competition day was an overcast day. But having the cells between the ribs gave us creativity points and using duct tape gave the judges a bit of a kick. We ended up with the most creative award and we're proud. From doing this project, you will learn so much about planes, solar energy, teamwork. It is a great way to spend a couple of weeks on a cool project.
Make sure that if you're interested in green technology and solar planes in general, check out the Swiss project Solar Impulse. Our team got to chat with them when they came to Dallas because of our involvement in a similar project. : http://www.solarimpulse.com/
This dude in Finland is also worth checking out. Here's his Facebook link: https://www.facebook.com/SolarDrone
Steps from here: To move beyond what we've created for now, we can add an auto-pilot system, cameras, and other equipment to make it a semi-autonomous drone. Light sensors can be added on either side of the wing and the plane can circle up the sky with maximum sun exposure on the panels; then at night, it can loiter around, slowly circling back down to Earth. This plan however, would require a new plane, a new design, and a lot of effort, but that is what we intend on doing next year. Heck, we could even connect the plane to a cell tower as one commenter below suggested. The GPS system would then tell people in the vicinity of the plane that the plane is there and the plane could fly over on top, giving the people a live bird's eye view of themselves. Awesome plan, right? The only part getting the technology down is acquiring FAA approval to do such a project.
Second Prize in the
Instructables Green Design Contest
Finalist in the
Launch It! Contest
Second Prize in the
Drones Contest
166 Comments
Question 3 years ago on Step 4
I had made a Glinder..also I had assemble solar panel on it...
But there is a problem how to assemvke that electric circuit ???
Please could you help me....
Please help immediately I have only 15 days for my science exhibition....
Question 4 years ago on Step 4
How to connect the solar panels to the battery
4 years ago
Did you ever plug the solar panels directly into the ESC/BEC?
Charging a battery mid-flight does not sound that efficient. Did you at least do a ground test without the battery?
4 years ago
What a seriously cool and fun project!!!
5 years ago
Very good. We are building our Solar Evolution here at the University of Kansas right now. We have everything together except the Solar Charger we ordered. It will be here soon. Then we start ground testing.
We used the Maxeon / Sun power C60 panels. We have 30 of them on a Bird of Time and currently output 18 VDC @ 6 Amps. more than enough to charge the batteries. We are hoping for an entire solar day plus at least 3 hours of operation.
Reply 5 years ago
Sweet! Please keep me posted on how everything goes. I am currently at the University of Houston - still working with sUAS on the side - but more so on the integration of sUAS into the public safety industry instead of R&D.
Reply 5 years ago
We do a lot of things relative to Aerospace Engineering. My current job function is to assist with development of Non-Linear Autonomous flight systems using H-Infinity, H2 and NMPC Robust controllers. I also work for the Department and assist with various Aerospace courses.
We have videos and discussions on our web site, YouTube, Twitter and Facebook.
https://ae.engr.ku.edu/
https://www.facebook.com/KUAEFlightResearchLab/
https://www.youtube.com/channel/UCxJ_tWwIbDKDDT7p8ySgJsw
https://twitter.com/HawkWorx
Best Regards,
5 years ago
How many did you connected parallel?
5 years ago
Hey! I've been going through this project for quite some time. And I have decided to make it for my final year project. But I have a problem with wiring in the fuselage . If you could help me out with some block diagram or ppt it would be very kind of you. Also the link that you provided in the intro doesn't work.
Reply 5 years ago
Hello - that is awesome that you are making this your final year project - the link should work:
https://drive.google.com/drive/u/0/folders/0B_bYmGJ0v1Ncb283TF8tWXF6ZWc
If not, PM me. Also check out Daniel Riley's YouTube Channel: rctestflight
He has gotten into Solar Airplanes and has been doing a really good job of making them.
7 years ago on Introduction
Awesome build, i love it.. You could add a micro controller with gps and program in a location and it will fly autonomously. did this with a quad copter had the micro controller set to the gps on my phone and it few 10 miles right to my position. all in all great job. i will def be building one of these. thank for the inspiration.
That is a total lie. A quadcopter capable of flying that far would cost thousands of dollars and use a 10000mah or more battery. How many cells did your lipo have? How many kv are the motors? Bet you don't know, or you seriously exaggerated.
Reply 5 years ago
i think he just meant the auto pilot part
I agree
This is a lie
Thank you!
For your quadcopter, what microcontroller did you use? APM I'm assuming? And 10 miles!? (totally not line of sight though if you're in the US...) How long is the flight time and what's your setup - radio system, battery, etc.? I have a quad with a 4000mah battery-around a 15 min flight time to 20%. Actually, I took a picture of my whole senior class using the quad on loiter mode.
5 years ago
also the power point is broken
5 years ago
i wanted to do this for a science fair project. i already have a built glider and i wanted to know how what solar panels, what motor should i use and if i need to place the panels under the monicoat because i dont want to open up my planes wing
5 years ago
can u help in making a solar power quadcopter....is it possible to make it n not use other source to charge it,to provide it power for flight....n how can we get control on its wait to make it efficient?
Reply 5 years ago
That is a great question. I am not really sure myself - my initial thoughts are that rotor powered aircraft would require a lot more power than a fixed wing aircraft because the rotors/propellers are the only source of lift and it only creates that when spinning at a certain RPM.
Feel free to ask around on other forums, but the best way I can think of to provide charge through a completely solar powered system is if you either 1) Tether your quadcopter to the ground and have a thin wire transmitting the power to the aircraft - the ground station would have a large solar array capable of collecting the required amount of energy for your quadcopter or 2) have a solar ground station that converts the solar power into a infrared laser beam that is shone at the flying quadcopter which has a receiver on it. Here's where I came up with that idea from: http://www.popsci.com/technology/article/2011-06/satellites-could-gather-energy-sun-and-beam-it-down-earth
With both of my ideas, your quadcopter would be limited in terms of range and the cost to build the ground station and create all this other stuff I just mentioned would certainly be out of your budget requirements. If you want to move forward with any of this, let me know and we can throw some more ideas together.
Is what I just mentioned practical? Maybe. Consider your POU (philosophy of use) and then determine what your best way is to proceed is. Let me know if you have any other questions or if you'd like to develop this concept further.
Best of luck.
