Introduction: Introduction to Ads Free Network Pi Hole
Nowadays, Ads are frustrating while surfing the internet. Due to pandemic, most of these days we are more adapted to the home Wi-Fi network usage. If you want to make your home network free from the Ads, Automatic malware protection and Adult content filtering. This is the most reliable solution
Pi-hole® | Network-wide Ad Blocking & Content Filtering Application.
Pi-hole or Pi hole is a Linux network-level advertisement and Internet tracker blocking application. Which acts as a DNS sinkhole and optionally a DHCP server, intended for use on a private network. It is designed for low-power embedded devices with network capability, such as the Raspberry Pi, but supports any Linux machines.
More About Pi-Hole
  • Raspberry PI ( For this project, I am using Raspberry PI3B)
  • PC / Laptop (Used to Configurations)
  • TFT Display (Optional)
  • Micro SD Card (16GB+)
  • HDMI Cable (Connecting PI to Monitor)
  • Monitor (Configure PI Settings)
Links :
Step 1: Installation & Configuration
  1. For this project, I'm using the Raspberry Pi OS Lite.
    Download - Raspberry Pi OS Lite
  2. Writing PI ROM to SD Card.
    Download - Raspberry Pi Imager
  3. After downloading above software. Install Pi Imager.
  4. Connect the SD card to the Computer and Burn the PI OS using Pi Imager.
Step 2: PI TFT Display
PiTFT Display
  1. Cut Trace
Use a hobby knife to mark in between the two pads and make sure it is deep enough to fully break the trace.
That's pretty much all we need to do to the PiTFT display!
Step 3: Connecting Raspberry Pi3B + TFT Display
Connect the PI Display TFT terminals to the Raspberry PI as shown in the figure.
Step 4: Raspberry Pi3B - Configuration SSH & Network
Connect the SD card to the system and Create a New File as "ssh" without any Extension as shown in this figure.
Step 5: Assigning Static IP to Raspberry PI ( Router Config )
I have assigned a static IP Address to the Raspberry Pi (MAC Id) in the Router Network IP configuration.
Step 6: Configure PiTFT Display With Putty
Connecting to Putty.
Follow the steps as displayed on the 1 & 2 reference Images for connecting to the Raspberry Pi Remote Shell. Proceed to the below Steps to configure the Pi-TFT Display.
Install PiTFT (fbcp) Support
This first sequence configures the system for the PiTFT display.
cd
sudo curl <a href="https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/master/pitft-fbcp.sh">  https://raw.githubusercontent.com/adafruit/Raspbe...> >pitft-fbcp.sh
sudo bash pitft-fbcp.sh
  1. Select the “Configure Options Manually” option, which sets up various system parameters to match this project.
  2. Answer “Yes” to the reboot question.
  3. Now finally you can able to see the Pi-TFT Display with the Linux screen booting up.
Step 7: Pi-Hole - Installation
To setup Pi Hole, from the command prompt (locally or remotely through SSH using Putty) use the below commands.
wget -O basic-install.sh https://install.pi-hole.net
sudo bash basic-install.sh
or try the below command
curl -sSL https://install.pi-hole.net  | sudo bash
Step 8: Pi-Hole - Installation - Welcome Screen
Pi-Hole installer prompts with the standard Debian wizard. Read through the introduction and press Enter to continue.
Step 9: Pi-Hole - Donation Screen
After installing PiHole, if it's really saving your bandwidth and improving network performance. I would greatly appreciate if possible you could give a donation to help them to continue to develop, provide support and give back to the community.
Donate – Pi-hole
Step 10: Pi-Hole - Static IP (Caution)
It is recommended to assign a static IP address to the PI before continuing to the next step. The router is configured as a DHCP server, It will be assigning the IP address to the devices which are connected to the router.
Note : You might face some issue when there is a Router Reboot and Pi is configured through the DHCP dynamically. It will auto assign the IP address to the Raspberry Pi. Pi-Hole host may not work properly.
Step 11: Pi-Hole - Interface Setup
For the performance of the Pi-Hole, I am going to use wired connection Ethernet (eth0) interface.
Step 12: Pi-Hole - DNS Provider Selection
I am selecting the Up Stream DNS Provider as the Cloudflare because comparing to the other DNS Providers it has the lot of good uses for the
DNS query data.
It collects limited DNS query data that is sent to our 1.1.1.1 resolver. Cloudflare 1.1.1.1 resolver service does not log personal information, and the bulk of the limited non-personally identifiable query data is only stored for 25 hours. --Introducing 1.1.1.1 for Families
Step 13: Pi-Hole - 3rd Party Blocklist Activation
Leave the current selection to default as shown in the screenshot which will allow Pi-Hole to block the Ads related domains by using the 3rd Party Services Block list.
Step 14: Pi-Hole - IPv4 & IPv6 Selection
I suggest leaving the defaults enabled as shown in the screenshot and continuing with Pi-Hole installation.
Step 15: Pi-Hole - IP Address & Gateway Configuration
As we have already configured the Static IP address for the Raspberry Pi. I suggest you to recheck the Local assigned IP address in the router and continue with the Pi-Hole installation.
Step 16: Pi-Hole - IP Conflict (Caution)
A warning message is displayed to recheck on the Static IP address assignment.
Step 17: Pi-Hole - Web Admin Interface Installation
I recommend selecting ON to install the Web Admin Interface. Which is very useful in Monitoring and Customizing the Pi-Hole.
Step 18: Pi-Hole - Web Server Installation
I recommend selecting ON to install the Web Server Interface. Which is very useful in Logging Queries, Maintains the Log Information and settings.
Step 19: Pi-Hole - Log Queries Setup
I recommend selecting ON to Enable the Log Queries which maintains the history of the web queries and useful in monitoring the web trafficking.
Step 20: Pi-Hole - Installation Successful
After successfully installing the Pi-Hole, The URL for the Web interface and the credentials will be displayed on the screen.
Note : Before clicking ok, I request you to note down the credentials of the web admin interface.
Forgot Pi Hole Password ?
Login to the Raspberry Pi using SSH into your Pi Hole server and use the command
pihole -a -p
to reset Pi Hole web interface password.
Step 21: Logging Into the Web Interface
There are three ways to get to the admin dashboard from your Web browser:
  1. http://IP_ADDRESS_OF_YOUR_PI_HOLE/admin/
  2. http:/pi.hole/admin
  3. http://pi.hole/
Step 22: Updating the Upstream Domains
I am using the additional benefits from the Cloudflare to block the Malware and Adult Content.
1.1.1.1 for Families is easy to set up and install, requiring just changing two numbers in the settings of your home devices or network router: your primary DNS and your secondary DNS. Setting up 1.1.1.1 for Families usually takes less than a minute and we've provided instructions for common devices and routers through the installation guide.
1.1.1.1 for Families has two default options: one that blocks malware and the other that blocks malware and adult content.
You choose which setting you want depending on which IP address you configure.
Malware Blocking Only
Primary DNS: 1.1.1.2
Secondary DNS: 1.0.0.2
Primary DNS: 1.1.1.3
Secondary DNS: 1.0.0.3
For IPv6 use: Malware Blocking Only
Primary DNS: 2606:4700:4700::1112
Secondary DNS: 2606:4700:4700::1002
Primary DNS: 2606:4700:4700::1113
Secondary DNS: 2606:4700:4700::1003
Step 23: Pi-Hole on Pi-TFT Display
Booting Pi-Hole on Raspberry Pi 3 with Adafruit PiTFT - 2.8" Display
