Introduction: Physics : Learn Physics the Fastest Way
Being a A+ student in Physics in my college didn't come from anywhere but my own strategy and hard work. During my basic physics classes i was bored and seemed a miss step in my career but then i found a easy way , a secret method actually to like, love and get the most in physics. So here i am to help you get started with physics and become a A+ student at it. Also for the secret, its somewhere in the texts beyond.
Physics :
It is what help us to understand our world better and to use this understanding for the benefits of people and environment. It involves the wide range of ideas and areas of investigations. It plays and important part in the the home, leisure, medicine and communication.
As with science it involves observations and experiments which are used to discover the relationship between things.
Who are the physicist ?
They try to make sense of relationships by developing theories and models. These theories are able to predict further behavior which can then be tested by experiments.
Physical quantities / Metric system
Note: Some people may think physics is really hard and confusing , that's right it is and that's what i still think, but remember its like a challenge and you need to refer this to real life situations and fight it to beat it. Just think it as a video game where you have evil bosses as formulas and equations and you are the ultimate formula killer etc.... have fun with something and you will learn. You know how i used to study ? . Well basically i wrote down a couple of problems in each A4 paper and then act as i am a super genius that is sent to earth to crack the most difficult equation. Then i used to make sounds say words and then solve and fall asleep. the next morning when it was exam time and the same kind of question appeared i was like " wow , it's time for super genius kid" hahah...sounds funny no ? ...but guess what i scored 20/20 in that exam , see what i mean ?...
System international Units - It is the standard system of units to measure all physical quantities , in other words the units in which the answer you write is gonna be in.
Length - Meter (m)
Mass - kilograms (kg)
Time - Seconds (s)
current - Ampere (a)
Temperature - kelvin (K)
Intensity - Candela (Cd)
Amount of substance - Mole (Mol)
Standard Prefix Multiplier
Tera - 10 * 12 ( * = power of)
Giga - 10 * 9
Mega - 10*6
Kilo - 10* 3
Centi - 10*-2
Milli - 10*-3
Micro- 10*-6
Nano - 10*-9
Pico - 10*-12
Peta - 10 *15
Femto - 10* -15
Exapmle 1 :
10 pM ----> M
10 x 10 * -12 m = This how you convert Pico Meter to Meter
Physics :
Length - Meter (m)
Time - Seconds (s)
Giga - 10 * 9
Mega - 10*6
Kilo - 10* 3
Centi - 10*-2
Milli - 10*-3
Micro- 10*-6
Nano - 10*-9
Pico - 10*-12
Peta - 10 *15
Femto - 10* -15
Exapmle 1 :
10 pM ----> M
Step 1: Length
It is some thing we have learned in junior college or secondary schools, In physics definition it is the distance from one point to another , take a look at the diagram to get a feeling of what ii am talking about. To find length we basically measure with a ruler , a meter ruler, and ever if it's really long use a Mileometer. That's basically really easy and you don't need much to understand here.
Area
it is the amount of surface for an object. For regular shapes we use formula for each shape and for irregular shapes we use grids and the count out the number of grids inside the figure. Thats the final area of that shape.
Volume
It is the amount of space a object takes up. The volume of regular objects are calculated by using formula's and of irregular are is found by displacement of water.
Some example of formula's to calculate volume are :
Cube - l2
Cuboid - L x w x h
Prism - Base area x height
Cylinder - TTr2 x height
Cone - 1/3 TTr2 x height
Pyramid - 1/3 base area x height
Sphere - 4/3 TTr3
Volume of irregular object
The volume of irregular objects can be found by using displacement method, for smaller objects a cylinder can be used but for larger objects we use a special equipment called the Eureka Can.
Experiment time.
Get a old cylinder can like a tin or a measuring cylinder if you have one. Choose the different types of objects you wanna find the volume of and then fill the cylinder with water of about 250 ml or 150 ml. Place the object in the water and then note down the new volume reading on the cylinder.
Formula = Final Measuring - Initial measuring
your new measure - 250 or 150
explore more ways and try to make your own formula to find other ways to find volumes of objects.
Area
Volume
Cube - l2
Cuboid - L x w x h
Sphere - 4/3 TTr3
Experiment time.
Step 2: Mass and Weight
Mass and weight are something which are always confused with people. Mass is the quantity of matter in an object while the weight refers to the gravitational pull on that object. Some one asks you what is you weight ? you would answer "ohh...my weight is 71 kg ", say that to a physics teacher or someone who knows it and they would laugh at you. Why ? because That means your 7.1 heavy or kg. Now let me explain. Mass never change and if your mass is 71 kilograms then the weight is basically your mass multiplied by the gravity (10) which gives you the actual weight on earth. So that means even if you are on the moon you would use the mass on earth which is 71 kilograms multiplied by the moons gravity.
Mass
Is how much Matter is in an object. It depends on the object size and the material it is made up of. Unit is in Kilograms (Kg). remember mass never changes , so if your mass on earth is 710 N and on moon will mass the same 710 N.
Weight
It is the gravitational pull on an object it is depended on the objects size and what it is made up of. Basically it means how much the power is used by the earths magnet to pull you. Units is Newtons (N).
To calculate weight :
W = Mass x Gravity pull where Gravity is = 10m/s2
So next time when someone ask you weight tell them that it's 710 or whatever Newtons and they will be shocked wondering what that it and how them that you know physic.
Mass
Weight
Step 3: Significant Figures
Rules of Significant figures
1. All zero digits placed in between non- zero digits are significant figures.
e.g - 101 - 3 s.f
2. All non- zero digits are significant
e.g - 1234 - 4 s.f
3. Zero placed after decimal place and before non zero digit are not significant.
e.g. - 0.01 - 1 s.f
4. Zeros placed after non zero digit behind the decimal points are significant.
e.g - 0.010048 - 5 s.f
5. Zeros at the end of a number are significant only if they are indicated to be so through the use of scientific notation.
e.g - 8200 - may have different significant figures.
(i) 8.2 x103 = 2 s.f
e.g - 101 - 3 s.f
e.g - 1234 - 4 s.f
e.g. - 0.01 - 1 s.f
Step 4: See You in Part 2
Ok ,this is the end of chapter one of this instructable but i will be back with chapter 2. I hope you have learned some tricks and tips on physics and some basic skills of physics. Next instructables will be more in depth with measurement errors, different types of measuring instruments, Drawing graphs etc. Until then please rate the instructable only at instructables.com.
