Introduction: Inverse Peanut Butter Cup Pie
In celebration of Pi Day, why not make a yummy treat that incorporates another mathematical favorite - inverse numbers.1
Standard peanut butter cups combine a chocolate exterior with creamy peanut butter insides, and they're fantastic. Though it may be hard to believe, when swapped to produce a peanut buttery crust filled with creamy chocolate filling, they're even more delicious.
1Geek note: The multiplicative inverse of a number (x), also called the reciprocal, is defined as 1/x or x-1
Step 1: You'll Need. . .
Software
For the Crust (amounts can be doubled if desired - this makes approximately 6 mini-pies or one 10 inch tart/pie):
Hardware
For the Crust:
- 1/2 cup all-purpose flour
- 1/2 teaspoon baking soda
- pinch of salt (approximately 1/16 teaspoon)
- 1/4 cup packed brown sugar
- 2 tablespoons sugar
- 4 tablespoons (or 1/4 cup or 1/2 stick) butter
- 1/2 cup smooth peanut butter, at room temperature
- 1/2 large egg (beat the egg, then measure out half of it)
- 1/4 teaspoon pure vanilla extract
- 1/8 cup cornstarch
- 1/4 cup sugar
- 1/16 teaspoon salt (a large pinch)
- 1/4 cup milk (2% or whole)
- 1 cup heavy cream
- 3 ounces semisweet or dark chocolate, coarsely chopped
- 1/2 teaspoon pure vanilla extract
- 2 tablespoons chopped peanuts or peanut butter powder (or powdered sugar if you prefer)
- If you want to get really fancy you can make a stencil using Shrinky Dink plastic similar to the one used for the heart stencil explained in steps 3 and 4 of these awesome anatomically correct brownies except it needs to be baked after cutting in order to shrink it
- you might also want to use a small fine mesh sieve if using peanut butter powder (or powdered sugar if you prefer) for even distribution
Hardware
For the Crust:
- large mixing bowl and wooden spoon or hand mixer (food processor can also be used)
- measuring cups and spoons
- small tart/pie pans (removable bottoms are strongly suggested) (this is the pan used here) - you can also make a larger pie if desired (crust should be enough for a 10 inch tart/pie pan - one with a removable bottom is suggested)
- plastic wrap
- dried beans or pie weights (optional)
- shot glass or spoon to press dough into pan (optional but suggested)
- heavy-bottomed sauce pot
- silicone spatula
- whisk (optional - needed if your pudding gets lumpy)
- fine mesh strainer (optional, also to prevent lumps)
Step 2: Peanut Buttery Crust (part 1)
- Stir together the white and brown sugar
- Add in butter and peanut butter and mix until combined (it will be very smooth and creamy)
- Add the egg and vanilla and stir until well combined
- Scrape down the sides of the bowl and add the flour, baking soda, and salt. Mix until just incorporated
- Wrap in plastic wrap and refrigerate at least an hour (or up to overnight)
Step 3: Peanut Buttery Crust (part 2)
- Press the dough into the tart pan evenly (you'll want a thickness of about 1/8 inch) - using a shot glass or the back of a spoon to press the dough helps create an even surface
- If you have any additional dough, it can be formed into cookies (classic peanut butter cookie shape works well) and baked alongside the tart shell
- Cover the tart pan with plastic wrap and refrigerate at least 1 hour
- Preheat oven to 375 degrees Fahrenheit and bake (with pie weights inside if using) for 9 to 11 minutes, or until golden brown (note: the crust will puff up some at first but will settle towards the end of baking)
- Remove from oven and allow to cool fully
Step 4: Chocolaty Goodness
- In a saucepan over low heat, combine cornstarch, sugar, and salt
- Slowly whisk in the milk and cream, scraping the sides and bottom of the pan with a silicone spatula to incorporate the dry ingredients
- Continue stirring over low/medium heat for 15 to 20 minutes until the mixture is thick enough to coat the back of a spoon. If lumps begin to form, use a whisk to beat them out
- Once the mixture begins to thicken, add the chocolate and continue stirring for 2 to 4 minutes until the pudding is smooth and thick
- Remove from heat and stir in the vanilla
- Pass the pudding mixture through a fine mesh strainer (if using) to remove any lumps
- Transfer to a bowl and allow to cool fully (refrigerate if desired)
Step 5: Assemble and Enjoy!
- Remove tart shells from pan (this is where a pan with removable bottoms comes in handy!)
- Spoon the cooled chocolate pudding into the tart shells
- Garnish with chopped peanuts or peanut butter powder if desired (I made a stencil using Shrinky Dink plastic - the technique for making the stencil is similar to the one used for the heart stencil explained in steps 3 and 4 of these awesome anatomically correct brownies except it needs to be baked after cutting in order to shrink it (Shrinky Dink plastic shrinks to about a third of its starting size during baking - make sure to factor that in when making your stencil))
- Keep refrigerated until ready to serve
- Enjoy!
