Introduction: Invisible Cd Shelf
Cd Shelf Levitation !
Step 1: What You'll Need
4 cd case
Medium sized "T" Bracket
Carpet Knife
Pen
wood screws
Epoxy Glue
Use Cd case you don't use again
Step 2: Cut and Measure
Measure the middle way point, make a mark, set down your bracket, draw an outline, measure again, cut out a hole deep enough that the bracket will set flush. You are doing this to the inside bottom of the Cd.Stick the bracket with epoxy glue.Make a slut on the top of the cover for closing the case.Insert the cd paper in the case for hidding the bracket.
Step 3: Hidding Bracket Part
Take 2 cd case and make a slit on both side.And take 1 cd and make a slit only on the bottom.Glued the 3 cd together.This part will hide the bracket and allow you to replace the shelf on other place .
Step 4: Enjoy !
mount your new invisible cd shelf on your desired wall.This cd shelf are a very cool and easy project .
