Introduction: Invisible Glue Joints: Connect a Round Object in 90 Degrees (werkplaatsidc)
In this instructable we will show you how to make an invisible wood glue connection without using a lot of (difficult) materials. The connection we talk about is specially for small connections.
What do you need?
- a drill (same thickness of the round object)
- wood glue (we use pattex express)
- a round object (max 20 mm diameter)
- a plate
- sanding paper
- clamps
Step 1: Drill a Hole
Drill a hole in the plate (not trough the plate) so the round object just fit in the hole.
Step 2: Sand the Round Object
Sand the corner of the round object at one side so you get a blunt tip in the same angle as the drill you used.
Step 3: Add Glue
Make the pieces free of dust. Add glue in the hole and on the corner of the round object.
Step 4: Put Together
Put the round object in the hole and put a clamp on it.
Step 5: Finish
Now the round object is connected in the shelf.
