Ipad 2 Laser Cut Stand
Intro: Ipad 2 Laser Cut Stand
This Instructables is easy and SOOOO useful. A good, cheap and simple stand for your Ipad 2. I mostly use my Ipad for Skype and for the calculator Application. I need it to be facing me and I don't always have an extra hand for it. All you need is a 4mm sheet of Acrylic and a laser cutter. Wood will also work if you prefer. Use the EPS file below and cut two hooks using the hairline thickness. Enjoy! You're welcome.
-Samuel Bernier
Project RE_
“Submitted by DIN 2012, Université de Montréal, industrial design program, for the Instructables Sponsorship Program”
-Samuel Bernier
Project RE_
18 Comments
lithboy 8 years ago
Grafted onto another cutting project at the last minute. Worked really well in 1/4" plywood. Thanks!
acti 12 years ago
I'm on a PC. Scanning the file, it seems to have been made on a Mac.
I'm assuming it may have some additional Mac file structure goodies
attached to it, which may be messing with reading it on a PC.
I tried a manual edit to fix the file, but I still can't open it in my image ware.
Is anyone else on a PC having trouble reading it?
earlyflyer 12 years ago
astack229 12 years ago
Thanks again to Samuel for the inspiration!
marlenedegrood 12 years ago
Questor 12 years ago
sokamiwohali 12 years ago
Excellent Instructable! I whipped out a pair using a pine 1x2. I just cut out the shape (using my bench top band saw) and sliced the 1x2 length-wise to make two. I used your file (had to download FreeFileViewer to see it) as inspiration, but wanted a slightly different angle. I used an angle that seems like it will work in my most-used places ( work conference room, home dining room table) without glare. I used pine to make sure I like the angle. I will remake them out of some hardwood I have laying around after I am sure about the angle.
Great idea. Thanks!
Samuel Bernier 12 years ago
Wragie 12 years ago
flyingpuppy 12 years ago
avengine 12 years ago
can you save it in lower version such as ai8, so that everyone can open it.
I like your design.
thanks.
wottebena 12 years ago
MerlinTheGreat 12 years ago
Sorry, but... what language do you speak?
If that is what you see in the file, have a look at it with Irfanview...
kost 12 years ago
WoundedEgo 12 years ago
