Introduction: Ipad Mini Dock
Take a block of wood length 9-10 cm roughly and 2 cm thick
Measure in from the end you want to be the front half a cm.
Take a file and file down roughly 1 cm so there is a divot in the block of wood now make this hole about 1 cm length ways or more depending what angle you want your ipad mini to sit at
If you want you can stick a piece of plastic on the top for a nicer finish or vanish the wood
I decided to stick bits of a cricket bat grip on the bottom so it wouldn't slip this was very effective but not necessary
If you want to round off the edges that can be done with sand paper.
It will not scratch your ipad mini as wood is softer than glass and aluminium
Thank you
