Iris Detection
Intro: Iris Detection
This project will crop the iris from an image.
STEP 1: Add a Video With an Eye Image
Add "From Multimedia File" block in Simulink and convert it to double type.
STEP 2: Find Pupil
Add in Simulink diagram 3 "Interpreted Matlab Function" Blocks.
The first one will find the x coordinate of the centre of pupil.
function [ center1] = findCentre1( gray_image )
[centers1, radii1] = imfindcircles(gray_image,[35 45],'ObjectPolarity','dark', ... 'Sensitivity',1);
center1=centers1(1,1);
end
The second block will find the y coordinate of the centre of pupil.
function [center2] = findCentre2( gray_image )
center2=centers1(1,2);
end
The last block will find the radius of pupil.
function [radii1 ] = findRadii1( gray_image )
radii1=radii1(1);
end
Then, add a mux block with 3 entries and a "Draw shapes " block (select circle as shape in block parameters). View the image with a "Video Viewer" block.
STEP 3: Find Iris
Add a user-defined system block. Here we will create a sobel edge detector .
The first one will find the x coordinate of the centre of iris.
function [ center3] = findCentre3( gray_image )
[centers2, radii2] = imfindcircles(gray_image,[99 110], 'ObjectPolarity','dark', ... 'Sensitivity',1,'Method','twostage');
center3=centers2(1,1);
end
The second block will find the y coordinate of the centre of iris.
function [ center4] = findCentre4( gray_image )
center4=centers2(1,2);
end
The last block will find the radius of iris.
function [radii2 ] = findRadii2( gray_image )
radii2=radii2(1); end
STEP 4: Create a Mask for Eyelid
Copy the user-define subsystem and paste it in the diagram. Change the constant to 3.
Convert the image to double type.
STEP 5: Crop Iris
Add 2 Matlab Function Blocks.
First:
function [Mask_row,Mask_column]= fcn(Mask,centre_x1,centre_y1,r1)
[row,column]=size(Mask);
row_mask=1;
column_mask=1;
Mask_r=zeros(row,column);
Mask_c=zeros(row,column);
for i=1:row
for j=1:column
if (centre_x1-i)^2+(centre_y1-j)^2-(r1+10)^2<=0
Mask(i,j)=1;
end
end
end
for i=1:row
for j=1:column
if Mask(i,j)==0;
Mask_r(row_mask)=i;
Mask_c(column_mask)=j;
row_mask=row_mask+1;
column_mask=column_mask+1;
end
end
end
Mask_row=Mask_r;
Mask_column=Mask_c;
end
Second:
function y = crop_iris(Image,centre_x1,centre_y1,r1,centre_x2,centre_y2,r2,Mask_row,Mask_column)
[row,column]=size(Image);
row_mask=1;
column_mask=1;
max_row=(max(max(Mask_row))+min(min(Mask_row)))*0.66;
for i=1:row
for j=1:column
if (centre_x1-i)^2+(centre_y1-j)^2-r1^2>=0
Image(i,j)=1;
end
if (centre_x2-i)^2+(centre_y2-j)^2-r2^2<=0
Image(i,j)=1;
end
if i==Mask_row(row_mask) && j==Mask_column(column_mask)
Image(i,j)=1;
end
end
end
y = Image;
DIY Hacks and How Tos 7 years ago
Interesting. I never really thought about how much coding had to go into something like facial recognition systems.
