Introduction: Iron Man Cabinet Upcycled From a Chest of Drawers
Someone was throwing away a chest of drawers so I decided to use it for a project I had coming up; making an Iron Man themed cabinet for a little lad to store his games and things in. I had a sheet of plywood recycled from an old bed frame and so used that for the bulk of the changes. The rest was done with glue, screws and paint.
Step 1: Tools and Materials
Tools:
- Pencil and rule
- Square and framing square
- Hand plane
- Scraper
- Flat head/Philips head screwdriver
- Hammer
- Mallet and chisel
- Router plane
- Crosscut saw, rip saw and tenon saw (or a table saw)
- Hand drill and brace (or power drill)
- 2mm and 8mm bit
- Clamps
- Coping saw
- Rasp and file
- Paintbrushes
- Dowel maker or dowels
- Knife
Materials
- Plywood (however much is needed to cover the drawers/make the cabinet of your piece)
- Glue
- Screws (however many needed to attach the cupboard insides and handles)
- Sandpaper
- Masking/Painters tape
- Paint stripper
- Hinges
Step 2: Stripping the Chest of Drawers, Planing and Sanding
I used some paint stripper and a scraper to get rid of most of the build up of grime on the chest of drawers as well as any varnish or wax that was present. A plane was needed to get the veneer off the top of the unit, not necessary when painting over it but I wanted to see what was underneath. All I needed then was a flat headed screwdriver and a hammer to get behind the handles and pry them off, they were held in with small nails. A few bits of sandpaper, 60 grit and then 240 grit handled all the sanding.
Step 3: Refining the Details
The beading on the chest of drawers didn't really fit in with the Iron Man theme so I got to getting rid of it. I used a 6mm chisel and a router plane to take it away from the front legs. I then used a smoothing plane around the edges of the top of the chest of drawers to take the beading away.
Whilst sanding I noticed some damage on one of the back corners of the top, my solution was to cut it flush and then repeat the same cut on the opposite side to make them match. Perhaps not the most elegant solution but it adds another interesting point to the cabinet.
Step 4: Making the Cupboard
The idea of this build was to turn the top left section of the drawers into a cupboard to store video games and what not inside. This involved taking out the long middle drawer and the upper left drawer. I then had to cut out half of the dividing piece that ran under the long middle drawer. This was achieved with a saw, a hammer, a chisel and just general twisting and breaking by hand.
I used part of the piece I cut out to make a new piece of frame to go against the small drawer, which was now located under the top small drawer. I screwed it into place.
The plywood sheet was perfect for filling in the cabinet sides that needed it. I had to measure and cut carefully for the plywood pieces to fit in as there were many awkward angles and pieces coming out of the inside of the unit. Once they were cut I pushed and banged them into place and finished securing them with screws.
Due to varying thicknesses of woods I had a small gap to fill in. Luckily some of the pieces I cut out were very close to the right size. I planed a piece down a little, cut out the right size and glued and clamped it into the gap.
Step 5: Fitting the New Drawer Fronts
The existing drawer fronts were too damaged and covered in old fashioned beading to be useful. I cut a piece of plywood which fit over the front of the unit and then cut it into 4 pieces; the cupboard door, 2 small drawers and the bottom drawer. I put these on with glue and some nails, I also fitted some screws on after the fact to keep them secure.
Step 6: Fitting the Cupboard Door
Fitting the hinges was fairly straightforward, I chiselled out two rebates for the hinges to screw into. When seated the hinges had to be flush with the leg in order for the cupboard door to sit flat against the unit. I then put the hinges in their closed position and laid the door on top of them in the desired position. I marked against the side of the door where the hinges would attach, opened up the hinges and screwed them on. I later fitted a little catch inside the cupboard door so it would click shut.
Step 7: Making and Fitting the Iron Man Mask
I created a template on Corel Draw to the right measurements, printed it out on four pieces of A4 paper and then glued them all together. After using some double sided tape to stick it to a piece of the reclaimed plywood I cut around it using a coping saw. Using a rasp, file and sandpaper I refined all the edges. I then took a sharp knife and cut through the paper into the wood along all of the detail lines. I used a chisel and router plane to cut out rebates for the eyes.
I laid the mask onto the cabinet and marked where the cuts would be, I then carefully cut each piece of the mask and attached them to the drawers and cupboard with glue and screws.
Step 8: Making and Fitting the Handles
I still had some plywood left over so I decided to make some very simple plywood handles. I cut five rectangles at 5cm X 3cm and another five rectangles at 7cm X 4cm. I then glued the smaller rectangles into the centre of the larger rectangles. The larger rectangles would be the actual handle. When the glue dried I chamfered all the edges of the handle part which was closer to the drawer, this makes the handles easier to hold.
I then drilled some pilot holes for screws through the front of the handles to the back and then some 8mm holes directly on top of the pilot holes. These holes only needed to go around 1cm deep to allow the screw to sit inside and a dowel to be placed on top. I found the centre of each drawer and the cupboard door, screwed the handles on, made a dowel with my dowel plate and inserted little pieces of dowel into each hole with glue.
When the glue dried I cut the dowels away with a flush cut saw and sanded down the whole cabinet.
Step 9: Painting the Cabinet and Making the Eyes
Now I would like to add that I'm not a painter and I'm not particularly skilled in this area! I bought some chalk furniture paint in varying shades to bring out the colours of Iron Man as well as I could. A lot of painters tape and patience was needed to paint the head to the best of my current ability. When that was finished and dried I sanded down and varnished the insides of the drawers and cupboard space.
Since I had already made rebates for the eyes I decided to insert some light blue card into them and then cover them with plastic. I got the plastic from an old VHS case and cut it up to just larger than the shape of the eyes. I then sanded and cut the plastic down slowly until it slotted into the rebate with force. Hopefully that'll be enough to keep it in there but if not I can return at a later date and glue them in.
Step 10: Finishing the Cabinet
I finished the cabinet with some spray varnish called Plasti-Kote, I did try and use some tinned varnish with a brush on a test piece but it made the chalk paint run and the colours combined. Its certainly not my usual kind of thing, my style is generally rustic/old fashioned and this is a rather modern looking piece of furniture and I used plywood! Something I really don't like using but it was ideal for this design.
I really hope you enjoyed this Instructable and the video, if you'd like to keep up with my future projects and check out my catalogue old projects already made then feel subscribe to my YouTube channel and like the Timber Anew Facebook page.
Thanks for checking this out and hopefully I'll catch you soon!
Third Prize in the
Reclaimed Contest 2017
25 Comments
4 years ago
Nice project. Glad to see you were using Stan Lee tools when making it!!
Reply 4 years ago
Haha! I told my bro that one, he had a rather good chuckle from it, I congratulate you on your pun work!
4 years ago
Brilliant work mate, this is top, I know a few people who would pay to price for something like this. Amazing !!!
Reply 4 years ago
Ah thanks a lot, I'm glad you like it!
4 years ago
Great Job!! I can't believe you're getting flack for doing this with an old dresser. Foolish. That thing was a mess and you made something awesome out of it! I'm sure the kid that was getting it wouldn't prefer you having restored it to its original shape. Keep up the great work! I am going to upgrade on this site just to download the plans! Love it!
Reply 4 years ago
Thank you Scott! I can understand where they're coming from, I realise it looks like a well made and elegant old dresser but the reality is that the workmanship and the hardware (handles, nails) point to it being made rather cheaply. As you say also it was in pretty poor condition but you can't change anyone's taste and I wouldn't want to, the world would be pretty boring if we did.
4 years ago
I think this looks nice. Two things I would have done differently: the background pain looks a bit too dark, not very upbeat, I would pick a bright blue or bright yellow. The other is that you do not really need those handles, you could have affixed the ironman head on another slightly smaller piece of plywood, so that you could directly pull on the head to open the drawers.
Reply 4 years ago
Yes I was trying to think of a way to do that with the head, the way the drawers are though they have to be pulled from the centre as if the handles are slightly to one side or the other they drawers would twist and kind of lock up. As for the colours I let the eventual owner choose them so I didn't have an option there. I think they were going for a kind of neutral colour that would fit into most rooms as they'll be moving soon. I would definitely try and incorporate that handle idea though somehow.
4 years ago
I would myself consider restoring the chest of drawers in question instead of "upcycling" it this way, it seems to have been an interesting piece once in the past.
Reply 4 years ago
It looks a lot better from a distance than it did up close, it wasn't very well made really. I can understand your sentiment though, this modern kind of look isn't my usual style but the chest was basically unwanted, destined for the rubbish and I was requested to make it into something different.
Reply 4 years ago
okay :-)
4 years ago
I just couldn't watch it... Don't get me wrong, you did a really nice job and I'm glad your son likes it but the original chest was so much more elegant.
Reply 4 years ago
I must agree. You just reduced the potencial value of that antique chest by 1000 percent.
Reply 4 years ago
I promise you, it was not an antique chest! It was really not very well made with many cheap fixings.
Reply 4 years ago
I understand, its not for everyone and its not my usual style. The chest of drawers was however moments away from being just another rotting piece of furniture in the landfill.
4 years ago
you should enter in Hand Tools Only Contests.
You deserve to win.
Reply 4 years ago
Thank you Simon! I tried that but I think because I published it before the contest was announced I cant do it? I'm not sure though.
4 years ago
Wow great job and you didn't use any power tools.
Reply 4 years ago
Thank you very much! Yes I like the simplicity of hand tools.
4 years ago
excellent!
