Introduction: Ironman
Things you'll need:
Laptop
Card stock
Pepakura viewer/designer
5mm plastazote/EVA foam
Knife and a load of blades
Glue gun and glue sticks
Velcro
Buckle clips
White LED's
Sandpaper
Engraver
PVA glue
Primer
Red and gold paint
Clear lacquer
And a shit load of patience :)
Laptop
Card stock
Velcro
Buckle clips
White LED's
Sandpaper
Engraver
PVA glue
Primer
Red and gold paint
Clear lacquer
Step 1:
Print off pep file on to the card stock and then I cut out the templates from the card stock. I then cut those templates into the plastazote foam one piece at a time, sometimes doing more if possible ( it all depends on curves, depths, angles etc.
Step 2: The Helmet
When all pieces I foam are cut out, I took my glue gun and started to glue the corresponding together, only gluing one side
Step 3:
When everything is glued I then covered the foam with PVA glue. A few coats 3 or 4 will do. Waterproof the lot of it
Step 4:
More to come soon
