Jailbreaking IPod 4th 6.1.5 Tethered
Intro: Jailbreaking IPod 4th 6.1.5 Tethered
Jailbreaking is a type of software hack that can let you do things that apple restricts you from doing. This can remove security though and not cooperate with applications or the app store. This also can lower your battery on your device as well so if you need battery this is not for you. This will let you do things like change status bar, customize your home screen or lock screen , get cool effects , record your screen and many more!
I AM NOT RESPONSIBLE! MAKE SURE YOU HAVE 50% OR HIGHER CHARGE!
STEP 1: Explaining Differences Between Tethered & Untethered
Tethered & untethered are the most common asked things when someone is planning to jailbreak. Tethered is a jailbreak that needs a computer when your device is shut off. This is confusing but for some devices , you can turn it on or it will not. I have not experienced it not turning on but it it doesn't chances are its in DFU mode. DFU mode is something that makes the device vulnerable to hacks, I often mix these up with recovery but they all really do the same in my opinion.
Untethered is where you can turn your device off and the jailbreak still works, which is not available at this time due to all the security on ios 6 that hacking teams are trying to crack and find exploits, tho 6.2 and under allowed untethered thanks to the evasion team!
STEP 2: Required Files
Now these files may not make sense to you but they will work for this. I recommend backing up your device before doing this.
iOS 6.0(NOTHING ABOVE OR BELOW CRUCIAL!) : http://www.felixbruns.de/iPod/firmware/
And for this, the tool being used will be Redsn0w (a common tool in the jailbreaking world)
http://www.redsn0w.us/2010/03/download-direct-links-jailbreak-guides.html (latest version recommeded!)
STEP 3: Starting and Configuring the Tool.
Once you have redsn0w and extracted it to your desktop(WinRAR is needed) you can now open it up. You will get a windows that has to buttons saying Jailbreak and Extras. Click extras and then click select ispw and find the 6.0 ispw you downloaded. Now your done configuring this. If by any chance you close the program ,YOU MUST REDO THIS STEP! Or you can mess up the process.
STEP 4: Now Jailbreak
Now your gonna wanna back out of Extras and go to jailbreak,It will say something about going into DFU. Make sure you follow the instructions or you will have to redo it again. Make sure your iPod is plugged in and in DFU and jailbreak it. If a check boxes come up Click Cydia and that's it, unless you want battery percentage. Click next and the jailbreak will be complete and your done.
