Introduction: Jalens Instructable
This is a how-to for my Instructable 2
Autodesk Inventor
Step 1: Step 1: Add Base Dimensions
after you have used the rectangle tool to draw out a base, then use dimension tool and make the length 136 and the height 78
Step 2: Step 2: Make a Cut
make the cut using the line tool and the dimension tool. the image above shows you need to make the cut 48 across. once you get the needed shape you just need to make the extrusion, and cut it out of the shape.
Step 3: Step 3: Filet
use the filet tool on the corners of the shape.
Step 4: Step 4: Cutting Holes
Use the circle tool to create the wholes. get the correct measurements on one side of the shape. Once you are sure everything is correct you use the mirror tool and the circles will match the other side of the shape.
Step 5: Step 5: First Shape
the shape should look like this when finished!
Step 6: Step 6: Start With a Base
use the circle tool and place it in the center with the correct diameter
Step 7: Step 7: Extrusion
Make and extrusion of 55mm
Step 8: Step 8: Extrusion
Make another extrusion 78 mm
Step 9: Step 9: Middle Extrusion and Filet
Us the Filet tool on the middle part of the shape
Step 10: Step 10: Filet
Add another filet at 3mm
Step 11: Step 11: Extrusion
This is the diameter of the circle in the middle to enable the extrusion
Step 12: Step 12: Base
Create a base with the circle tool at 100!
Step 13: Step 13: Add 2 More
Add 2 more circles to the shape. The bigger one dimension is 36 and the smaller one is 24
Step 14: Step 14: Start the Extrusion
make another extrusion of 10 mm
Step 15: Step 15: Extrusion
Make an extrusion with the two circles you previously recorded at 30 mm
Step 16: Step 16: Extrusion
Make another extrusion where the image above suggest 20 mm.
Step 17: Step 17: Wheel Range
Make the radius 97, leading to extrusion and filet
Step 18: Step 18: Filet
Use the filet tool around the top circular shape of the wheel
Step 19: Step 19: Finished
you have completed the wheel
Step 20: Step 20: Assembly
once finished with all of your shapes, put each shape into a drawing format. The shape needs to have a shaded iso and the other sides unshaded. The shape needs to have dimensions on it.
