Introduction: Japanese Geta
This is a tutorial on how to make your own pair of Geta. (this is the real way of making them. these are made from one piece of oak instead of 3 glued together.)
It is fairly easy but you do need some moderate wood working skills.
I have made longbows and other stuff from wood before so I know how it will behave
This pair of geta's will be made from Oak.
Step 1: Choosing the Wood
The choise of wood is important.
You dont want it too be full of cracks and holes.
I have already mesured and cut out for each foot on the picture below.
Cut about 1 cm from your foot because then you will be able to shape your geta later.
Step 2: Start Sanding and Sanding
What you need to do now is sand down the rough surface with a sandpaper (I used grit 120)
And when you are done with the first one then its on too the next one.
(this took me about 5 hours to complete because I wanted it too look really nice)
Step 3: The All Important Teeth
When you are about to make the teeth I have one very important scentence for you.
TAKE IT SLOOOOOW.
First mark out were you want your teeth
there are really no standards to where and how high but a minimum of 4 cm high is recommended. (I have seen some that are as high as 17 cm !!!)
Use a chisel (i think that its the right name) and a hammer to slowly remove the wood.
Make sure you dont hurt the teeths.
Do this on both shoes :P
OBS the front shall be a bit longer than the back. for more easy walking
Step 4: Start Sanding and Sanding Again
Start sanding with a wood rasp on the bottom and make it look good
Step 5: Round the Edges and Strengthening the Teeth
Now its time to round the edges you do this best with a rasp .
then sand it down again so it look nice.
then oil it with treeoil.
after this is done you need too strengthen the teeths.
First drill two holes in each teeth then fill it with glue and the hammer in a plug and chop it off.
Leave it to dry for a while
Now you can also decide were the holes for the Hanao (thong) should be. and drill them ( you can use a powerdrill here but I used a Handdrill)
Step 6: Sew the Hanao
I used strong wool fabric on the outside of the Hanao and inside its a "rope" of hemp.
I did forget to take picture while sewing but it shouldnt be a problem. Just sew it to your foot size and it should be fine.
(drill larger holes if you need to I needed to re drill 3 times xD )
Step 7: Finishing the Geta
When you have tweaked all the little problems and have attached the Hanao securly then go out and let the world know that you have a pair of geta's (atleast let them hear it)
(About a week later I did put rubber soles on the teeths too protect them and make the noise lower, it also makes them look fancy)
がんばってね :D
This was my first instructable
I hope you enjoyed it :P
またね!
1 Person Made This Project!
- 40wolvesadancing made it!
49 Comments
1 year ago
onpa hienot. kokeilen ittekkin
5 years ago
i don't have a chisel what should i use in its place
Reply 5 years ago
maybe a saw would work :) and smash out the middle part with a hammer or something
6 years ago
Hey 40wolvesdancing, where did you get that pair of geta? Did you make those?
7 years ago on Introduction
how do you measure size?
Measure your foot, though your heel should stick out a bit from the back, look at pictures of people wearing geta and you'll see. Also when making for women the overall shape should be more rounded of, mine is more round now than in these pictures.
7 years ago
Sugoi!
Reply 7 years ago
ありがとう , although there are some improvements made to them now :)
Reply 7 years ago
These are mine. I didnt make them from one solid price of wood. And I need to sand them more. But the part I had most trouble with was the hanao.. I made these myself. Good thing I can sew :)
ah お疲れさまでした
Reply 7 years ago
You see the picture?
Reply 7 years ago
Where is my picture:/
Reply 7 years ago
Ohaiyo ancaf33-chan.. Genki desu ka? Anata ga e o matte imasu?
The rope at the top of the clog seems to go down in the middle, instead of offset towards the big toe.. doesn't that make it akward, or is it meant for stability Speaking of which, what's the maximum weight undeneath it can support?
I'd like to make it 22cm tall (9").. any recommendations since finding such a piece of wood is unlikely?
Hi I put my foot on the piece of wood when I chose where to put the hole, and maybe I put it a bit more towards the middle, because of estetics.. well since I made mine (maybe a bit too) very sturdy it will not break because of the weight. but since you want to make it that tall, you would have to need to make them fairly thick and with the strengthening woodpegs running through, you can make it of cheaper wood and just glue on rubbersoles (on the teeth) which I did with mine, which made it possible to walk on asphalt without ruining them :) and if you want to use oak or such, go to where people go to buy wood for repairing like their wooden boats, there you can buy it :)
7 years ago
They were NOT easy to make, but they turned out so well after all the hard work. Walking on them for 2 days straight was painful, but so worth it. People kept asking where did I buy them, and I was happy to tell them they were hand maid.
Reply 7 years ago
nice looking pair of getas :D よくできました!
Reply 7 years ago
Thank you for the tutorial ^^
8 years ago on Introduction
What are the benefits to these shoes? I can only assume that since historically these shoes have been worn for centuries that they have some long term benefit or perhaps an attribute that is revealed over time. Footwear back in those days was primarily functional, even for the people with more money than the rest. And yet I just can't seem to imagine a benefit or even a terrain where these are 'The perfect fit"... I just wonder why these never gave way entirely to Tabi, (Another shoe of ancient Japanese design, much more like an ordinary, modern-day shoe only with a split between the big toe and the rest of the shoe which enhances traction.) Any ideas?
They were used in bad weather so the hakama("pants") did not get wet, at other times they used Zori. Geisha also used geta, the tabi shoe was invented in the 20th century from what I have heard (the ninja shoe) the traditional tabi socks however have been around very long :) , I have also heard that they could secure geta with additional string around the ankle down to the shoe.
