Java Basics
Intro: Java Basics
STEP 1: Open Notepad
STEP 2: Enter the Code
In writing a java program, it always begin with public class _________(Enter the name of your Program)
Then Write the code provided
public class Sample
{ public static void main(String args[])
System.out.println("Hi...This is my First Java Program");
It is necessary that you should all the things given above or simply copy them
STEP 3: Saving It
When you are going to save a java program, it is necessary to write the same name which you have written in the class name with a '.java' extension
STEP 4: Running a Program
Then you have to open cmd
For opening cmd just type it in the search box and do the following steps
- Navigate to the place where you saved your program in cmd
- Then type 'set path=C:\Program Files\Java\jdk1.8.0_101\bin' but change the version according to your jdk.
- Press Enter
- Then type 'javac'
- Then type 'javac Sample.java' Where I have type Sample.java you have to replace it with your file name
- If any errors were there then it would be shown on the screen.
- After correcting those errors do the 5th step again.
- Type 'java Sample' Where I have type Sample you have to replace it with your file name.
- Your program is ready
STEP 5: Important Points
- Your class name should start with a capital letter
- While typing your message, you should add inverted commas or it will show errors
- After typing your message, add a colon (;).
3 Comments
DIY Hacks and How Tos 7 years ago
Great first instructable. Very well written.
Pranav Tyagi 6 years ago
Thanks
Pranav Tyagi 7 years ago
Thanks
