Introduction: Java Code/Program - Area and Volume of Icosahedron (20 Sided Sphere)
A Java program that calculates the area and volume of an icosahedron, which is a 20 sided sphere (also known as a polyhedron).
Uses java.util.Scanner and java.lang.Math classes
File attached.
// Matt R test Java program
// Created using BlueJ IDE www.BlueJ.org
// Program that calculates icosahedron area and volume
// Import Scanner class
import java.util.Scanner;
// Import Math class for square root and power calculations
import java.lang.Math;
public class MattCalculateIcosahedron
public static void main(String[] args)
System.out.println("Calculate the area and volume of an icosahedron.");
System.out.println("An icosahedron has 20 sides.");
System.out.print("Enter the length of an edge: ");
// Create Scanner object called keyboardinput
Scanner keyboardinput = new Scanner(System.in);
// Put input into variable "edgelength"
double edgelength = keyboardinput.nextDouble();
System.out.println("===============");
// Calculate area of icosahedron
System.out.println("The formula for the area is: 5 * square root of 3 * (side squared)");
double squarerootof3 = Math.sqrt(3);
double areaoficosahedron = (5 * squarerootof3) * (Math.pow(edgelength,2));
System.out.print("The area of the icosahedron is: ");
System.out.println(areaoficosahedron);
System.out.println("=============");
System.out.println("Now we will calculate the volume of an icosahedron.");
System.out.println("The formula for the volume is: (5/12) * (3 + (square root of 5) * [length of edge cubed])");
double lengthOfEdgeCubed = (Math.pow(edgelength,3));
System.out.println("Length of edge cubed: " + lengthOfEdgeCubed);
double squarerootof5 = Math.sqrt(5);
System.out.println("Square root of 5: " + squarerootof5);
double squareRootPlusEdgeCubed = squarerootof5 + lengthOfEdgeCubed;
System.out.println("Square root plus edge cubed is: " + squareRootPlusEdgeCubed);
double fiveDividedBy12 = 5.0/12.0;
System.out.println("5 divided by 12 is: " + fiveDividedBy12);
double volumeoficosahedron = (fiveDividedBy12) * (3 + squarerootof5) * (lengthOfEdgeCubed);
System.out.println("================");
System.out.println("The volume of the icosahedron is: " + volumeoficosahedron);
} // end of public static void main(String[] args)
} // end of public class MattCalculateIcosahedron
- BlueJ IDE
- WIndows, Linux or Mac OS X
Step 1: Code
// Import Scanner class <br>import java.util.Scanner;
public class MattCalculateIcosahedron {
public static void main(String[] args) {
} // end of public class MattCalculateIcosahedron</a><p><a href="http://www.BlueJ.org"></a></p>
