Introduction: Jeep Wrangler JK LED Headlight Anti-Flicker Decoders
With automotive lighting technology getting better by the day, it's actually pretty flabbergasting that halogen headlights are still fairly common. If you've ever driven on the road and seen the difference between LED and halogen, you would have probably hopped on the computer to research these new headlights the second you got home.
Many owners of the Jeep Wrangler JK opt to get aftermarket LED headlights as they are a very popular solution. Fortunately, you don't have to spend a crazy amount equivalent to the sticker price of a new car. Stock halogen headlights don't have anything on LED headlights and you will wonder why you didn't make the jump sooner.
However, due to the on-board computer in Jeeps, there is a slight flickering that can be seen. Many people just dealt with the flickering since it was still better than stock, but now, there are Anti-Flicker Decoders on Amazon for Jeeps that have the 7" Round LED headlight assembly.
Step 1:
You'd probably wonder if this little decoder set really works. This decoder kit really does all it promises and more. This H4-to-H13 anti-flicker decoders get rid of the annoying flicker issue once and for all.
Step 2:
Do these anti-flicker decoders really work? Yes! All you need to do is plug in the decoder in between the LED headlamp and the stock harness.
Step 3:
Can you use your high beams? Yes! These anti-flicker decoders allow you to use your high beams so they are not compromised.
Is there a delay when you switch between high beam and low beam? There is no delay when you switch from high beam to low beam.
Step 4:
Is it easy to connect these anti-flicker decoders to the LED headlamps? Yes! Everything is just plug-and-play. These anti-flicker decoders are even waterproof so you don't have to deal with any water related issues.
Step 5:
Is the light output dimmer due to the design? You'll actually notice that the harness makes the LED lights brighter.
Step 6:
This is the solution that many Jeep owners have been requesting since the stock halogen headlights are a complete joke. Not only are they extremely dim, but they are completely unacceptable for a car of that caliber. Installing these Jeep Wrangler JK anti-flicker decoders is a piece of cake, and all Jeep owners can install these onto their car.
