Introduction: Jeep Wrangler Paracord Handles
I have a Jeep Wrangler and have been wanting handles made for awhile now. I decided to make some on my own. These handles are simple and made out of 3 materials and can be made in minutes. These are the perfect alternative to high dollar handles, My total cost for the materials came to twenty-two dollars.
For this DIY you will need few supplies:
Scissors
A lighter/heat source
Velcro
Paracord (at least two cords)
Breakaway Buckles
Side note: All supplies may be found at hobby lobby
Step 1: Attach Cords to the Buckle
Run cords through the buckle and secure them as shown.
Step 2: Begin to Braid the Cords
Pull left black cord under middle cords and over the pink, then pink over middle cords and under left black cord, then pull tightly.
Step 3: Continue to Braid the Cords
Continue the pattern of braiding until your desired length, ideally 8 inches.
Step 4: Cut Cords
Cut the remainder of the cords after you have reached the desired length.
Step 5: Tie Off the Cords
Flip over the paracord handle and make the same pattern tie on the backside.
Step 6: Secure the Cords to the Other Buckle
In order to secure the cords from coming apart, use the lighter to singe the ends of the cords.
Step 7: Time for Velcro!
Measure your velcro out to approximately 8 Inches and cut it.
Step 8: Assemble the Straps
Connect the velcro to each other matching up only a few inches, then slide them through the buckle and connect at desired diameter.
Step 9: Complete Handles!
After the straps have been attached your Jeep Wrangler Paracord Handles are complete!
Step 10: Placing Them in Your Wrangler
Slide the single strap around your roll bar and fasten the velcro together at your desired width!
