Introduction: Jellyfish Pendent
I made this for a friend and she loved it so let me share with the rest of you. Sorry there are not a lot of pictures. I always dive head first and then after the fact think of taking pictures . Plus what else would you do with those old forks you have lying around haha. Mine I found in my back yard while putting in a new fence.
Step 1: What You Will Need
Files
Saw ( I used a jewelers saw)
Blow torch
Pliers
Safety equipment (gloves, goggles,)
Dremel or a flex shaft (optional but helps file it down faster)
Sandpaper various grits
polishing wheel and some polishing compound
Blow torch
Pliers
Step 2: Kill It With Fire
Put on some heat resistant gloves and fire up the blow torch. Get the prongs nice and hot. You may want to do them one at a time because they will cool off to fast. Now bend and twist the prongs into the shape of your tentacles.
Step 3: Cut Off the Head
Now take your saw and saw off the head as close as you can towards the rounded part.
Step 4: Sand and Polish
Now file the little left from sawing it off. Now you will more than likely need a little sanding and a good buffing because of using the blow torch has left it a little blackened. Once that is done just drill a hole in the body or solder on a jump ring and there you go.
