Introduction: JetJolt K'nex Gun
My first instuctable - the gun is okay, featuring a new firing method I invented. It shoots between 30-45 feet, though I've occasionally gotten over 50. Easy to load, make and shoot and in general a good firing technique.
Step 1: What You Will Need
To make this gun, you will need:
6 gray rods
15 purple/silver connectors
1 blue connector
5 white/black connectors
8 blue rods + 1 for firing
10 red/grey connectors
6 yellow/grey-white connectors
1 orange/brown connector
1 red/green rod
4 blue spacers
4 silver spacers
30 green/black rods
5 dark gray connectors
1 black stange connector (stubs)
6 gray rods
1 blue connector
1 red/green rod
4 blue spacers
4 silver spacers
30 green/black rods
Step 2: Construct the Front of the Gun
Constuct the front part of the gun according to the images below. Note that if you used a large rubber band you should triple it before use, a medium sized rubber band should be doubled and smaller ones left the way they are. Also remember to twist the rubber band around the middle as seen in the images. Not doing so will not allow the gun to fire.
Step 3: Construct the Middle of the Gun and the Firing Rod
1) Create the firing rod.
2) Create the middle of the gun and insert the firing pin through the hole. Note which side of the firing rod faces which direction.
3) Connect this with the part made last step as seen in the image.
Step 4: Construct the Trigger
Probably the most complex part of this gun, the trigger must be powerful enough to withstand the force of the rubber band while pulling the firing pin back. Construct it based on the images below.
Step 5: Create the Back of the Gun
There isn't much to this part of the gun. Make it based on the images below.
Step 6: Finish the Gun
1) Slide the trigger on to the back of the gun (here you see the back part of the front piece of the gun connected to the back part of the gun, it's just there to show you how to connect the back part to the front with the trigger on)
2) Connect the back part of the gun to the front and the trigger to the firing rod.
Step 7: How to Load and Shoot
To Load:
1) Make sure the "arms" of the strange black connector fit around the rubber band as seen he image below.
2) Hold the trigger in one hand.
3) With the other hand, push a blue rod through the hole of the black/white circular connector into the strange black connector so that the rubber bands are in between the strange black connector and the blue rod as seen in the second picture.
To Shoot:
1) In one hand, hold the front of the gun.
2) With the other, quickly pull back the trigger. The gun will fire the blue rod.
Happy building!
To Shoot:
Happy building!
