Introduction: Null
wings inspired by the p51 mustang for low drag. bearing designed based on the jewel bearing in clocks, which has a low drag and durable design. handle means people with reduced dexterity can still use the spinner safely. bearing is designed to incorporate N52 grade 1mmx12mm Neodymium magnets, which will suspend the spinner from the upper half, further reducing drag. this design does not require wing weights, and can be used as the basis for air driven, rope or pull cord designs. the pivots can further be improved by using superglue to not only join all parts, but coat the pivots as a hard jewel surface.
