Introduction: Jewellery Making Projects-splendid Bezel Bracelet With Birthstones
This stunning jewellery making project will instruct you on how to create a bracelet with birthstones. All the things that you’ll need are birthstones of your choice, several cabochon settings, a clasp and some jumprings.
The steps for making the bracelet with birthstones are as easy as making resin items. However, in this jewellery making project, we use materials that can be handled more easily and safely. Once you have finished your bracelet, there will be no reason to leave the wrists bare! This tutorial is fun, simple and full of bling.
Materials needed in this jewellery making project:
Birthstones (I use rhinestone beads here)
Matching Cabochon Setting
Clasp
Jumpring
Glue
Chain (optional)
Bent Nose Plier
Clasp
Jumpring
Glue
Chain (optional)
Bent Nose Plier
Step 1: Connect the Cabochon Settings
1. Flatten two opposite loops on the bezel with bent nose pliers. Repeat for every bezel;
2. Connect as many cabochon settings using jumprings until you get the desired length for the entire bracelet.
Step 2: Decorate With Crystal Birthstones
Apply dots of glue on back of each rhinestone bead and then place them into the bezel neatly. Press firmly.
Set aside until all of them have completely dried.
Step 3: Design a Closure
Take the last bezels on the bracelet and attach a jumpring on each end. Then, attach a lobster claw clasp on one of the jumprings. Leave the other jumpring free; it will serve as the link that the clasp closes on. Tada! Here it is!
If you are having trouble with making your beads or cabochon fit into the bezel, you can solve the problem by replacing the bezels with a different size or shape bezel. All kinds of types of cabochon settings in jewellery making projects can be bought from the craft shops or online easily and conveniently. If you need more detailed info, please head over to our homepage: www.pandahall.com!
