Introduction: Jewelry Stand
For my girlfriend`s birthday, i decided to made a jewelry stand for all her jewels (but it wasn`t enought).
I have to say that it wasn`t in my mind to make and instructable so i didn`t take photos of the process, but i will try to explain it in the better way so you could get it
Step 1: Prototype
the first thing i did it is to took old pieces of wood to get my prototype and decide the measures. i think that it is 15mm of thickness, whit all the cut pieces i made a quick sketch
Step 2: Assemble
Then i got the full idea of my project so only y have to assemble in the same way that the prototype, but before that i decorated it decopauge technique all the frames.
the first one that i done was the base frame, and then appart prepare the "body" frame when lately is going to be the divisions and sections
Step 3: Getting the Form
After i get the frames and decorated it, i get a long piece of black fabric and glued to the bottom of the body frame so in that way i could get a better looking of the bottom.
So them put the dividers and the section as the sketch from the top to the bottom, the first one it is in 18 centimeters, then 30 cm, again 18 cm, 12cm, and the two last ones from 10 cm.
In the from of each divider i put a kind of top so you can leave things.
Attached to the first and second divider there are a several amount of hook so you can hang your necklaces
Step 4: Earrings Frame
In inside the front door you have a frame with several stick where can be used to hang earrings
Step 5: Final Decoration and Filling Up
For the outside of the door it is decorated with an illustration of the "le pettit prince" handmade painted with acrylic.
And finally enjoy filling your jewelry stand :D
