Introduction: Jolt Mod
First instructable in a while that I’ve done, hope you like it
Jolt
Triad
Screwdriver or long pliers
(Optional) Rubber bands
Triad
Step 1: Air Restrictor
Take your screwdriver(or long pliers) and knock or pull out the air restrictor.
Step 2: Triad Spring
Unscrew the bottom of your triad, take out the plunger, and unscrew the top.
Next, take the spring, and set it aside. Unscrew the bottom of your jolt, and do the same steps listed before this point*
Put the triad spring on the plunger,and put the plunger head back on, and screw it back on.
Place the plunger back into the blaster, and screw the bottom plate back in
* Unscrewing the plunger head will not work with newer jolt models because it has a rivet instead of a screw.
Step 3: (Optional) Rubber Bands
Strap a rubber band on top and strap it to the priming handle.
Simple as that.
Simple as that.
Step 4: Done!
Now you have a stronger jolt, enjoy.
