Introduction: D4E1 Juggle Tube
Since twisting the ring around your arm can hurt, we looked for a tool that avoids this problem. She is easy and pleasant to use, as there are handles and the bow prevents the ring from touching your body.
- multilayer tube (easier to bend)
- two handles
- one inner tube
- juggling ring(s)
You can buy the two handles, the inner tube and the jiggle ring in the Decathlon. The tube is easy to find online or in a DIY shop like Brico.
Step 1: Cut 1 Meter of the Tube With the Saw
Afterwards, sand the tube if necessary.
Step 2: Cut the Tire With the Scissors
1 piece 45 cm and 2 pieces of 13 cm or the handle lenght.
Step 3: Pull the Bicycle Tyre Over the Middle of the Tube
Insert the 45 cm piece halfway. You can use an air gun to make it easier.
Step 4: The Sides
Insert both 13 cm pieces on the sides of the tube.
Step 5: The Handles
Slide the handles over the ends of the tube.
Step 6: Bending
Bend the tube according to preference. Ready to use!
