Introduction: Jumping Spider
☆ This instructable is going to show you how to reuse some packaging foam, pipe cleaners, feathers and beads to make a cute pretend jumping spider!
I really like how jumping spiders look, they're so cute! The model I decided to create is based on a male jumping spider (Platycryptus undatus) you can easily make a female jumping spider using this instructable. The male jumping spiders can grow to be approximately 13 mm long. This jumping spider is approximately 11 times bigger than an actual male jumping spider.
☆ This jumping spider does not jump...Please someone make version that does jump and share your build with the rest of us!! ☆
(Note: The image of an actual live female jumping spider, I had taken a few years ago when my toddler pointed it out in our garden ♡ . ☆
• beads for spider eyes sizes:
2 = 8 mm round beads silver color
2 = 6 mm round beads silver color or abs color crystals.
2 = 3 mm round beads silver color or abs crystals.
• 2 = soft down turkey feathers, approximately 2 inches in length.
• 4 x 6 inch 1 inch wide = Polyethylene/Polyurethane/Convoluted Foam/ charcoal grey color
• 1 white chalk ( to draw spider body outline on foam).
• 1 pair of scissors
• 4 crafting pipe cleaners, white or grey color ( for the legs):
2 = 8 inches long
2 = 7 inches long
• 2 pipe cleaners 2 inches long white or grey ( for the fangs)
• 1 grey marker ( to color the pipe cleaners).
• 1 black marker ( to color designs on spider body).
• 1= 6 x 6 inches piece of felt grey color ( for designs on the body).
• optional: 2 triplet opals oval shape size: 8mm x 10mm ( to super glue position between the pipe cleaner fangs).
• Gorilla Super Glue ( gel formula).
Step 1:
Step 2:
back body portion measured 3.25 inches long
Step 3:
Take the white pipe cleaners and color them grey; with the grey marker.
Step 4:
Cut about 2 - 3 designs out felt ( 1 piece for the head and 1 for the back portion of the foam spider. Now set them aside for gluing on to the body later.
Step 5:
Step 6:
Place the 2" pipe cleaners one at a time in to the front of the head about 8mm under were the eyes will be of to the left and right side in the front of the head. Leave 1" of pipe cleaners poking out and bend to desired shape.
Step 7:
With the black marker make designs/ markings on your spiders body and head.
Step 8:
With the super glue, glue the triplet opals on the inside of the pipe cleaner fangs, next to each other angled top ends of the opals slightly towards each other.
Step 9:
Cut the other turkey freather in half. Sick the pieces of feathers one under each fang in the hole were the pipe cleaner fangs are located.
☆ Your done! Successful cute pretend spider build! ☆
