Introduction: K'NEX Mini Hand Gun KNEX
This is my KNEX Mini Hand Gun that shoots farely fast.
This is my first instructable. It has a block trigger. I made this when i was bored and to see how to make an instructable.
Step 1: Knex Mini Hand Gun
My Knex mini Hand gun uses 17 Red Conectors, 4 orange conectors, 1 dark grey conector, 1 light blue conector, 3 white rods, 2 red/green rods, 6 green/black small rods and one rubber band.
It uses a block trigger and fires one white rod or two black or green small rods.
Step 2: Barrel
The barrel uses 10 red conectors and one red rod.
Step 3: Trigger, Firing Pin and Handle
The Trigger uses: 1 white rod, 1 green rod and 1 orange conector.
The Firing Pin Uses: 1 red rod, 1 light blue conector and 1 dark grey conector.
The Handle uses: 3 green rods, 3 orange conectors and 1 white rod.
Step 4: Adding the Trigger and Second Barrel
Picture 1: slide the trigger onto the red rod through the hole.
Picture 2: Attach 7 more red conectors onto the red/green rod.
Step 5: Adding the Handle
slide the handle onto the second barrel which contains 7 red conectors.
Step 6: The Firing Pin
Picture 1: Insert the firing pin through the second barrel through the hole.
Picture 2: Put a strong rubber band through the dark gray conector on the firing pin.
Step 7: Where to Put the Rubber Band
Put the rubber band around the handle to the end of the hand gun.
With the right side put it around the front of the hand gun.
Step 8: !!!!Completed!!!!
Warning Do NOT shoot at anyone or something that you do NOT want to Destroy.
Have Fun!
Have Fun!
